nissanman312 Posted August 31, 2016 Share Posted August 31, 2016 (edited) The guys over the water seem to quote some big numbers on like for like mods Is there some reason for this other than than the fact everything has to be massive over in the stated? Do they measure bhp differently somehow ? They all seem to quote the sort of whp we see at the fly when going fi etc Edited August 31, 2016 by nissanman312 Quote Link to comment Share on other sites More sharing options...
Richf Posted August 31, 2016 Share Posted August 31, 2016 They often use Dynojet dynos which over read by some margin There is a comparison tool here its for Supra but gives a good idea of the difference between a Dyno Dynamics and Dynojet dyno http://mkiv.supras.org.nz/dyno.htm Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 31, 2016 Share Posted August 31, 2016 Everything in America is bigger: Horsepower, food, women... 2 Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted August 31, 2016 Share Posted August 31, 2016 Everything in America is bigger: Horsepower, food, women... Except mc Donald's I went in for a Big Mac when we were there to see, and it was the same size as over here! I was not impress 😂 Sent from my iPhone using hammer and chisel! Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted August 31, 2016 Share Posted August 31, 2016 Everything in America is bigger: Horsepower, food, women... Except mc Donald's I went in for a Big Mac when we were there to see, and it was the same size as over here! I was not impress í ½í¸‚ I did exactly the same when I was at LAX once, for some reason I assumed a US Big Mac would be massive. As it was it wasnt even as good as the UK version. 1 Quote Link to comment Share on other sites More sharing options...
Snjur Posted August 31, 2016 Share Posted August 31, 2016 They use a term of whp but what i manage to figure out those whp seam to be equal to our bhp. Sent from my SM-G850F using Tapatalk Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 31, 2016 Share Posted August 31, 2016 i think the correction factor has its part to play Quote Link to comment Share on other sites More sharing options...
Richf Posted August 31, 2016 Share Posted August 31, 2016 This article explains the number fudge that Dynojet use http://www.hotrod.com/articles/dynojet-chassis-dyno/ Quote Link to comment Share on other sites More sharing options...
Richf Posted August 31, 2016 Share Posted August 31, 2016 If you are up for reading articles then this one explains why there is no fixed amount for drivetrain losses and how the more power you make the higher losses will be (Something thats overlooked by some tuners) http://www.superstreetonline.com/how-to/engine/modp-1005-drivetrain-power-loss/ 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 31, 2016 Share Posted August 31, 2016 That's a good read Basically, dynos mean chuff all in terms of absolute numbers. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 31, 2016 Share Posted August 31, 2016 (edited) If you are up for reading articles then this one explains why there is no fixed amount for drivetrain losses and how the more power you make the higher losses will be (Something thats overlooked by some tuners) http://www.superstre...ain-power-loss/ What method do you use to generate a vehicles bhp? I still feel bhp is a better measure than whp: I understand that you use a coast down test to determine flywheel power. Why, when wheel power is what makes you go? The problem with measuring wheel power only, is that many factors can affect the wheel power output - tyre design, temperature and pressure, wheel alignments, gear box oil, viscosity temperature and level, wheel speed, final drive ratios etc. As an example; take two very similar cars with similar modifications, both are tested on a 'wheel horse power only' dyno, Car A has 12hp more at the wheels than Car B. The owner of Car B and the dyno operator begin looking for problems with the turbo chargers, ECU calibrations, CAM timing etc. If the test had been carried out on the Dastek Dyno, the coast down test would have revealed the transmission loss would have appeared excessively high, thus taking the focus away from the engine fault and pointing us in the direction if the drive line problem. The fault was in fact a partially seized brake caliper, which was converting the power into heat. Edited August 31, 2016 by davey_83 Quote Link to comment Share on other sites More sharing options...
Richf Posted August 31, 2016 Share Posted August 31, 2016 Apart from coast down losses not being consistent either As pointed out here Coast-down tests are sometimes used on a dyno to attempt to measure frictional losses, but because this test is not dynamic (meaning they're not done while accelerating, but rather while coasting to a stop with the direct drive gear engaged but the clutch depressed so that the engine and transmission aren't linked) it really only captures steady-state drivetrain losses as well as rolling resistance. Wheel power is pretty much as unadulterated as you can get 1 Quote Link to comment Share on other sites More sharing options...
Flex Posted August 31, 2016 Share Posted August 31, 2016 Would my dong be bigger in the US? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 31, 2016 Share Posted August 31, 2016 Would my dong be bigger in the US? Measure it millimetres, it'll be mahoosive 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 31, 2016 Share Posted August 31, 2016 Or get a midget to hold it. Quote Link to comment Share on other sites More sharing options...
Flex Posted September 1, 2016 Share Posted September 1, 2016 Kinky 1 Quote Link to comment Share on other sites More sharing options...
TT350 Posted September 1, 2016 Share Posted September 1, 2016 US bhp depends on how many "yoooooo sick bro!" You say while dynoing. And additional "hoooooooooooo shnap dawg!" You say after. UK bhp depends on how hard you fold your arms and frown while its dynoing. 1 Quote Link to comment Share on other sites More sharing options...
KyleR Posted October 28, 2016 Share Posted October 28, 2016 They all have Nismo stickers on their cars over there, they add like 20% at the wheels bruh! Quote Link to comment Share on other sites More sharing options...
Djan Posted January 8, 2017 Share Posted January 8, 2017 The whole concept of brake horse power is a little weird to be honest, if you look back at where the phrase and workings come from, it's a measurement for how far a single horse can plough a field in a given time. Now getting back to the size of your dong, that'd be a different kind of ploughing. Maybe American dirt is thinner than ours and generally weaker so they have higher measures. Personally I like the folded arm rationale, makes way more sense to me. Quote Link to comment Share on other sites More sharing options...
