Back end feels light / floaty
leebottrill
Also check drop links, and other suspension stuff under there too.
Could just be the weather though: A downpour after a sustained period of very warm weather will bring oils to the road surface, so it'll be much slipperier than if it had just been a regular bit of rain.
I had the same sort of problem , turns out it was the bushing in the camber arms , problem is you can't by the bush you have to buy the arm , and you can't buy 1 you gotta buy 2 , but it was worth it to get the solid drive feel back.not sure if that helps or not lol
