Xtreme SMF & Twin Plate Clutch Problem
.:Bullen:.
Hi guys just fitted the Xtreme twin plate clutch & solid flywheel. All went ok and bolted back together however the clutch pedal travel is now really high when biting and when it does bite it sounds as though its perhaps catching or sliping ?
Any ideas on how to sort it ive googled and read about adjusting the clutch pedal travel which i did wind out 2 turns but not sure that helped ha
Thanks in advance
Yeah it was Clark Motorsport I have pinged them a email to see if they have any advice
I am sure that Ewen will respond as soon as he picks up your email.
Not sure what he is up to today but should be back in the office Monday morning. :thumbs:
  • 3 weeks later...
  • 1 month later...
It turns out was just the noise from the solid flywheel, once the revs rise it's not an issue. I did adjust the pedal but done it too low so I need to raise that back up again but other then that happy with the clutch kit so far
