mancks68 Posted August 27, 2016 Share Posted August 27, 2016 I've just bought a 2002 fairlady Gt with 60k on the clock. Had been stood for 23 months and frites into life with the 1st click of the key with help for jump leads. I've done the basics aux belts tyres oil filters boot struts and re greesed the brakes. It's totally original ie jap radio no mods at all. Is there any thing else I should lookout for with a car stood this long ? Also what would the power gain and cost of a straight throug exhaust system be? Cheers guys 👠Quote Link to comment Share on other sites More sharing options...
Sargara Posted August 27, 2016 Share Posted August 27, 2016 Tyres. Even if the tread is decent id get them swapped straight away, could be cracking after being stood for so long. Dont skimp on them either, the Zed is not a car you want to have cheap/mismatched fitted to. Quote Link to comment Share on other sites More sharing options...
evest Posted August 27, 2016 Share Posted August 27, 2016 Probably worth a full service really. See how the battery fares and take it easy whilst the various oils recirculate around the moving parts. If its had no problems previously you should be okay. Lots of different exhausts out there and HFCS are a popular mod as well. Most will save weight and improve sound etc.. not sure on real power gains without a remap though. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 27, 2016 Share Posted August 27, 2016 Quote Link to comment Share on other sites More sharing options...
mancks68 Posted August 27, 2016 Author Share Posted August 27, 2016 Yeah I've done the tyres first thing I did Put some continentals on with 4.5 MM. of tread on em Not ideal but money dictated £130 for all four Quote Link to comment Share on other sites More sharing options...
evest Posted August 27, 2016 Share Posted August 27, 2016 Ps - welcome to the forum! Quote Link to comment Share on other sites More sharing options...
mancks68 Posted August 27, 2016 Author Share Posted August 27, 2016 Yeah done the service as well apart from plugs they look tricky to get too HFCS !! I'll have a look at that cheers Not that botherd about more power as the car has fire in its belly as it is. A clearer exhaust not would probably give more smiles for Buck Thx 1 Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted August 27, 2016 Share Posted August 27, 2016 Hi and welcome along 😎 Sent from my iPhone using hammer and chisel! Quote Link to comment Share on other sites More sharing options...
mancks68 Posted August 27, 2016 Author Share Posted August 27, 2016 Thx for the welcom btw Quote Link to comment Share on other sites More sharing options...
evest Posted August 27, 2016 Share Posted August 27, 2016 (edited) I see you're in Manchester - clearly a good lad then! Check out Lockwood & Greenwood in audenshaw - highly recommended by many on here for servicing, repairs etc.. Think they still do a forum discount too Edited August 27, 2016 by evest Quote Link to comment Share on other sites More sharing options...
Stemo Posted August 27, 2016 Share Posted August 27, 2016 Yeah done the service as well apart from plugs they look tricky to get too It maybe takes few hours maximum, you just have to remove the intake plenum to get them out. Plenty of DIY guides on forums aswell. Quote Link to comment Share on other sites More sharing options...
evest Posted August 27, 2016 Share Posted August 27, 2016 (edited) Whoa! Neggers cheggers! Definitely no need to remove the plenum: 1. disconnect battery 2. strut brace off 3. airbox and pipe off 4. coil packs out (will need to temporarily shift a few brackets/looms) cylinder 5 is a PITA! 5. Swap plugs (if you're feeling old school, check new spark plug gaps with a feeler guage to be sure they're good) 6. Replace everything in reverse order 7. Job's a goodun, cup of tea! Also a good opportunity to check condition of old plugs for any sign of engine issues (crusty tips, oil on the threads, etc...) (Although if you do remove the plenum, you may as well take the opportunity to put a plenum spacer in! ) Edited August 27, 2016 by evest Quote Link to comment Share on other sites More sharing options...
mancks68 Posted August 27, 2016 Author Share Posted August 27, 2016 Nice 1 lads for the tips Lockwood & Greenwood in audenshaw are only 2 miles for me good shout í ½í± Is there any different from my fairlady to a uk spec car ? I know it was imported in 2007 for 20k and been with the same owner since then. It was a bit of a barn find really full of spider webs n moss around bonnet lines Lights where a bit faded with the sun but machine polished out mint. Tar Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted August 27, 2016 Share Posted August 27, 2016 Welcome to the forum. Only thing i can think of if it hasn't been done already is a remap for UK 98ron fuel as Jap fuel is of a higher spec, I suppose that would have already been done if it was imported by a reputable company though. Quote Link to comment Share on other sites More sharing options...
HiddenWomble Posted August 28, 2016 Share Posted August 28, 2016 if you've just removed the oxidisation from the lights you will then need to re-seal the plastic to avoid them oxidising straight away. that way your clear headlights will stay nice and clear. have a browse about for some guides on the matter. if you plan to take her somewhere without a speed limit (track/autobahn) then i believe the jap cars are restricted to 112mph, so you might want to get that removed when you do a remap to get the benefit from any performance mods you do (mostly breathing mods for the DE) for jap vs uk take a look at this post: http://www.350z-uk.com/index.php?showtopic=1648 welcome and enjoy your new zed Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 29, 2016 Share Posted August 29, 2016 Hello and welcome Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted August 29, 2016 Share Posted August 29, 2016 along Quote Link to comment Share on other sites More sharing options...
The Big Miester Posted August 29, 2016 Share Posted August 29, 2016 Hello and welcome to the forum Quote Link to comment Share on other sites More sharing options...
mctwistuk Posted August 29, 2016 Share Posted August 29, 2016 Hello and welcome Quote Link to comment Share on other sites More sharing options...
