Chris141084 Posted August 26, 2016 Share Posted August 26, 2016 I've just serviced my 04 De and changed the spark plugs for iridium ones. While I'd got the inlet pipe off I thought I'd clean out my throttle valve, now my tick over is higher 1000 rpm, and when gearing down to stop at lights etc the revs stick at 1100 ish for a few seconds then drop down again. Once the engine is warm and has driven a few miles it seems to tick over fine. Thought there might be some kind of throttle valve reset procedure? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 26, 2016 Share Posted August 26, 2016 Yes, do the resets. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 26, 2016 Share Posted August 26, 2016 http://www.350z-uk.com/topic/53148-how-to-ecu-accelerator-pedal-throttle-valve-resets/ Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 26, 2016 Share Posted August 26, 2016 if it doesn't work first time stick at it and press the throttle pedal faster on/off, it does work Quote Link to comment Share on other sites More sharing options...
Chris141084 Posted August 26, 2016 Author Share Posted August 26, 2016 Cheers guys, I'll try it in the morning :-) Quote Link to comment Share on other sites More sharing options...
Chris141084 Posted August 27, 2016 Author Share Posted August 27, 2016 These resets did the trick, she's running perfectly now :-) Quote Link to comment Share on other sites More sharing options...
