Hig Posted August 25, 2016 Share Posted August 25, 2016 Hi all, Has anyone replaced the following: Rubber trim on the roof that sits under the trim that goes over the side windows (sits between the roof and the trim) Rubber trim that runs up each pillar of the windscreen (sits between glass and pillar) I ask because the windscreen one has managed to come loose at the bottom and was sticking out until I pushed it back in, but it is now shorter than the opposite side which doesn't look right. The roof one is similar in that it keeps on coming out from under the trim and I keep on having to push it back in every so often, so now I'm thinking it might be best just to replace it all. Thanks, Matthew Quote Link to comment Share on other sites More sharing options...
FMJ Posted August 28, 2016 Share Posted August 28, 2016 Hi Hig This trim is part of the plastic roof trim and if your lucky you may be able to re stick it with a water proof double sided tape. if you need to remove the roof trim be very careful as it don't take much to break the plastic trim.oh to replace with a new park from a main stealer it's just over £300 unless you can fined a second hand one. good luck FMJ Quote Link to comment Share on other sites More sharing options...
