Lowrcase Posted August 24, 2016 Share Posted August 24, 2016 I have a 2006 roadster with the DE engine, it's a RevUp spec engine that comes with all the usual goodies, bhp & torque. I currently have stainless headers, stainless decats & stainless twin exhaust system(based on the HKS 1), JR Performance panel filter in a standard air box, plenum spacer from H-Dev & grounding kit also from H-Dev. She's also just been serviced recently with nice new plugs, oil & coolant. Also have had H-Dev remap her. On the day I had a Pipercross Viper fitter & it was super hot! The filter was actually killing power! I drove in with 165bhp & drive out with 175bhp! Plus they couldn't get the intake air temp below 51 degrees C! Went home & put the standard air box back in & dropped the JR Performance panel filter in & this Sunday just gone had her tested again whilst at the Japanese Performance Show & she kicked out 292.5bhp!!! Not bad for a ten year old engine which had just ticked over to 101k miles me thinks. Anyhoo I want the 300bhp that Nissan say should be! I will be going for a turbo conversion in 2018 & a stroker kit in 2019 but I want the elusive 300 for now. So what else can I do to get that extra 8hp? Is a fuel pressure regulator any good for owt? Any help would be awesomes guys!ðŸ‘🻠Quote Link to comment Share on other sites More sharing options...
brillomaster Posted August 24, 2016 Share Posted August 24, 2016 try a few different dynos, i'm sure one of them will give you a piece of paper with 300 on it but to be honest that sounds about right for an na engine - cams are the only thing I can think of, or try and get the rev limit raised by a few hundred rpm if the engine will take it. Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 There isn't much point in raising the limiter as the peak power is still @ 6600rpm & fallen off slightly by time you hit the stock limiter. I was thinking cams but read somewhere that NA came are no good in a boosted motor??? Don't know how that would work as I thought cams were cams regardless of FI or NA! Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 24, 2016 Share Posted August 24, 2016 Lovely motor pal, saw it Sunday. Hhhmmm lightweight crack pulley bigger throttle body? You'd probably get 300bhp+ on a dynojet and from my understanding JPS read low for figures full bolt on DC5 made 226bhp and our red DE on display made 262bhp iirc (not standard car) Quote Link to comment Share on other sites More sharing options...
taybo Posted August 24, 2016 Share Posted August 24, 2016 I know your pain. Mine just dynoed at 299 bhp! Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 24, 2016 Share Posted August 24, 2016 Revup is 296bhp, not 300. Brillo is spot on though, different dyno on a different day will give you a different result. You could gain the equivalent of that 'missing' 4bhp by having a good poo and clearing the rubbish out the boot before driving, if you're that keen. Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 17:33, davey_83 said: Lovely motor pal, saw it Sunday. Hhhmmm lightweight crack pulley bigger throttle body? You'd probably get 300bhp+ on a dynojet and from my understanding JPS read low for figures full bolt on DC5 made 226bhp and our red DE on display made 262bhp iirc (not standard car) Thanks man, I was looking at the lightweight pulley kit you can get. 3 pulleys including the crank, alternator & power steering pump. Also where can I get a bigger throttle body? I've read about some people fitting Mustang 5.0 throttles but it's hassle!🤔 I ported & polished the head on my last motor but it took a while & that was just a 4-pot head!😂 Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 (edited) On 24/08/2016 at 18:00, taybo said: I know your pain. Mine just dynoed at 299 bhp! Totally gutting man!😢😢😢 Edited August 24, 2016 by Lowrcase Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 18:02, Ekona said: Revup is 296bhp, not 300. Brillo is spot on though, different dyno on a different day will give you a different result. You could gain the equivalent of that 'missing' 4bhp by having a good poo and clearing the rubbish out the boot before driving, if you're that keen. I know the RevUp is 300ps so equates to 297bhp. The boot only had cleaning products in it!😂 I'd also had a mahoosive poo before hand!😂 I forgot to say that I've only ever run the car on 99 octane V-Power fuel also. Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 I also also forgot to say that I have a polished aluminium Z-Tube. What about a terra-clean or some other deep clean? Failing that where would I get a larger throttle body? I'd polish the @*!# out of it before fitting! Would an oil catch can do anything as I wouldn't be sucking in them nasty vapours anymore? Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 24, 2016 Share Posted August 24, 2016 In all honesty number chasing is never a good idea as it tells very little about how quick a car is in real world terms. As long as the torque delivery is smooth that's more important for an engine than peak power for a split second. Remember on a track Sabine would make mince meat of any of us in a factory standard Zed compared to normal folk in a lightly modded one, point is enjoy the motor Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 24, 2016 Share Posted August 24, 2016 Dyno it in January, you'll have your 300 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 24, 2016 Share Posted August 24, 2016 Or turn the aircon off! ...You did have the AC off, didn't you? You're going to kick yourself now if you didn't Quote Link to comment Share on other sites More sharing options...
evest Posted August 24, 2016 Share Posted August 24, 2016 After reading this I decided the put my stock airbox back in (was running a Takeda Attack Short Ram). Genuinely feels like I've just gained (well... replaced) a nice chunk of low -mid power. Not remapped or tested on a dyno yet but it's on the list... A mate of mine has a boosted Lotus Esprit so we're on a friendly bet to see who can top 300bhp first - just for the hell of it!! Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 24, 2016 Share Posted August 24, 2016 Your gearbox will last longer than his 1 Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 19:11, KyleR said: Dyno it in January, you'll have your 300 Nice cold heavy air! Lush! Lol Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 20:03, Ekona said: Or turn the aircon off! ...You did have the AC off, didn't you? You're going to kick yourself now if you didn't Oh damn I knew I forgot summat! Lolol A/C was off & the roof down. FTW!😠Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 19:10, davey_83 said: In all honesty number chasing is never a good idea as it tells very little about how quick a car is in real world terms. As long as the torque delivery is smooth that's more important for an engine than peak power for a split second. Remember on a track Sabine would make mince meat of any of us in a factory standard Zed compared to normal folk in a lightly modded one, point is enjoy the motor My power is down from new & all that but the torque is just a bit higher than standard @ 263ft/lbs so she pulls like a train. Mad that I've lost power in my 10 year old engine with 101k miles but I've got more torque.ðŸ˜ðŸ‘🻠Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 24, 2016 Share Posted August 24, 2016 Place this on your plenum before the next run Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 20:05, evest said: After reading this I decided the put my stock airbox back in (was running a Takeda Attack Short Ram). Genuinely feels like I've just gained (well... replaced) a nice chunk of low -mid power. Not remapped or tested on a dyno yet but it's on the list... A mate of mine has a boosted Lotus Esprit so we're on a friendly bet to see who can top 300bhp first - just for the hell of it!! I couldn't believe that I gained 17/18hp by going back to the stock air box with a decent panel filter but the dyno figures show it. It feels so much better with the stock box also, a lot more responsive throughout the whole rev range. Definitely recommend the JR Performance filter & a good price from H-Dev also.ðŸ˜ðŸ˜ðŸ˜ 1 Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 On 24/08/2016 at 20:41, davey_83 said: Place this on your plenum before the next run Then I'll have a slightly soggy engine!😂😂😂😂😂 Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 24, 2016 Author Share Posted August 24, 2016 Has anyone done water meth injection? We got 2 screen wash bottles so 1 could be converted easily enough!🤔 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 25, 2016 Share Posted August 25, 2016 Can't compare figures from two different dyno's Quote Link to comment Share on other sites More sharing options...
Lowrcase Posted August 25, 2016 Author Share Posted August 25, 2016 On 25/08/2016 at 05:46, davey_83 said: Can't compare figures from two different dyno's I know & then there things like air temp, altitude above sew level & barometric pressure on the day but it's a rough guide. Nothing more Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 25, 2016 Share Posted August 25, 2016 Not even a rough guide, as in the same day you could go to three different dyno's and get very varied figures. Not so much of an issue for those BIG power cars as 600bhp or 620bhp isn't going to loose anyone sleep lol 275bhp to 295bhp for example possibly could - my 2c Quote Link to comment Share on other sites More sharing options...
