barryda Posted February 5, 2008 Share Posted February 5, 2008 Hi I wonder if anyone can help, my Z has recently used more oil than normal and it has just started to make a ticking noise from the engine whilst running... How serious is this ? ... could it be the top end, bottom end ...lifters ? any advise on what this could potentially be and how much it could cost would be appreciated ... Really worried it could be serious, but I've had no warning light apart from the oil light came on a few weeks back and that's when I topped up the oil... My Z is a 03 Jap Import 59k Thanks Bazza Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 5, 2008 Share Posted February 5, 2008 What's your oil pressure at idle when its well warmed up - 15psi is normal. Does it increase up to 30-40 when warmed up and giving it some gas? Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 Hi I'm not usre as I think my oil gauge may be incorrect as it has always sat in the middle i.e @ 60 an then icrease up towards the 120 when you put your foot down ... does this help ? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 5, 2008 Share Posted February 5, 2008 Your oil pressure readings are odd if they are the warmed up values (and are actually pressure) - on cold start, they are what you would expect. This may be my bad info: JDM owners - is the gauge on JDM pressure or level (I'm not sure)? Your gonna need to give some more info i) where do you think the noise is coming from ii) can you hear it just at idle or when you are driving iii) does the frequency/volume of the tick change with engine speed iv) can you take and post a sound clip ps I don't think the Z has tappets/hydraulic lifters but it has cam components which if worn could make a ticking noise varying with engine speed pps the noise may be entirely unrelated to oil level/oil issue Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 I think it is coming from the top of the engine.. It sounds like a tapping noise.. it seems to be a bit louder when the car has been driven for a while.. You cant really here it from inside the car only outside and when you press the accelerator the freqeuncy increase... I'm not able to take a sound clip Any ideas ? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 5, 2008 Share Posted February 5, 2008 - cat vibration but unlikely - is your drive belt in good nick or worn/frayed? - any change if you have clutch depressed - worn cam followers but hope not i have seen, but cannot find, a TSB for a fuel damper issue, which is a common problem but the tick would not change with revs - anyone got that TSB? Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 is it going to be expensive if it is cam followers ? Could this be top end or bottom end replacement ? any idea on cost if it is one of these ? ... I might be talking rubbish Im a bit out of my depth here Thanks Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 5, 2008 Share Posted February 5, 2008 if you have run low on oil , I would suggest as a matter of urgency ! replacing the oil and oil filter, preferably with good quality oil.. it may be one of your hydraulic tappet's gummed up Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 5, 2008 Share Posted February 5, 2008 TSB which I just found on the knowledge base for the fuel damper I would say cam followers would be expensive because cam replacement is 12-16 hours labour but I don't really know. Let's hope its not that anyway - that's the last thing to go for, one step at a time You must get a sound clip and maybe someone like Tere can advise, it's so difficult to diagnose remotely without this input Quote Link to comment Share on other sites More sharing options...
martinmac Posted February 5, 2008 Share Posted February 5, 2008 Where abouts are you bud, this may help. Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 Thanks for the info... how do you get the hydraulic tappets cleaned up or should the new oil and filter help free this ? any other ideas of what it could be if this does not work ? Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 Thanks for the file i'll take a look... Anybody know how much cam followers would be ? Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 Im in Wiltshire Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 5, 2008 Share Posted February 5, 2008 barryda said: Thanks for the info... how do you get the hydraulic tappets cleaned up or should the new oil and filter help free this ? any other ideas of what it could be if this does not work ? try the new oil and filter first , then worry what else it might be if that doesnt work One things for sure it will be expensive if it doesnt Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 5, 2008 Share Posted February 5, 2008 Agreed - get some 10w-40 high quality oil (motul or silkolene for example) from oilman in there; don't go for a 0w- or 5w- in your case this once, go for the more viscous 10w- stuff The objective of the oil in this mix is to reduce wear by reducing the dynamic (sliding) friction (think that's what its called) between cam and follower, if you have an issue, a more viscous oil will tend to 'stick' more between the opposing surfaces - that's why I'm suggesting it As to cost, the problem is that the cam and cam followers wear with each other and if one needs replacing, so does the other and that is big bucks, as lomoto says On the plus side, there is no real history of excessive cam wear with this car, so unless you really ran very dry on oil for an extended period, it's probably not this fingers crossed Quote Link to comment Share on other sites More sharing options...
barryda Posted February 5, 2008 Author Share Posted February 5, 2008 I just tried taking a sound clip but it doesn't come out that clear.... the noise is coming from the top of the engine towards the back of the engine bay a big metal housing... see if this clip helps Quote Link to comment Share on other sites More sharing options...
Emperor Ming Posted February 5, 2008 Share Posted February 5, 2008 It sounds like a dry cam follower?? With the engine running use a long bladed screw driver and place the metal end on various parts of the engine and at the same time place your ear on the end of the handle. This will amplify the noise and allow you to find out exactly where it is coming from. By moving the blade of the screw driver slowly over the top of the engine it is possible to even pin point which cam follower it is - if it is one!! Be careful not to catch a belt with the screw driver though!!!!!!!! Tell us EXACTLY where it was loudest and we may be able to pin point your problem before you start paying garage fee's Let us know the result Ming the old fashioned Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 6, 2008 Share Posted February 6, 2008 barryda said: Hi Really worried it could be serious, but I've had no warning light apart from the oil light came on a few weeks back and that's when I topped up the oil... The light coming on doesn't mean you're low on oil it means your oil pump is pumping air. Not good at all. How long was the light on for and what speed/engine revs were at the time Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 6, 2008 Share Posted February 6, 2008 M13KYF said: barryda said: Hi Really worried it could be serious, but I've had no warning light apart from the oil light came on a few weeks back and that's when I topped up the oil... The light coming on doesn't mean you're low on oil it means your oil pump is pumping air. Not good at all. How long was the light on for and what speed/engine revs were at the time Agreed. Going back to your first post, when you say 'topped up with oil', how much did you have to add because a) if it was a lot, you could well have been running into oil starvation in the engine if it was not a lot, you need to check that you have added enough. I count one litre as a 'top-up' whereas the engine holds 4.7 litres in total. Anyway, get it changed and get this stuff in as soon as http://www.opieoils.co.uk/p-1145-silkol ... gines.aspx ps good advice from Ming the Tin Ear Quote Link to comment Share on other sites More sharing options...
barryda Posted February 7, 2008 Author Share Posted February 7, 2008 I took the car to a Nissan dealer and they have advised that it is not burning oil but they do want to strip the head to find out what the issue is.... the have qouted 19 hours to strip the head @ a cost of £1518.. then the additonal cost for any parts ... HELP !! ..... does anyone know a cheaper option ?? i.e non main dealer ?? and if it is not burning oil what could it be ? is it the Cam folowers / lifters ?? .. Nissan don't want to comment ? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 7, 2008 Share Posted February 7, 2008 where are you based Quote Link to comment Share on other sites More sharing options...
martinmac Posted February 7, 2008 Share Posted February 7, 2008 M13KYF said: where are you based Hes in Wiltshire Mike which doesnt throw up any obvious solutions, cany think of anyone down there. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 7, 2008 Share Posted February 7, 2008 can only think of TDI but the other side of London in Thurrock http://www.tdi-plc.com/ Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted February 7, 2008 Share Posted February 7, 2008 M13KYF said: can only think of TDI but the other side of London in Thurrock http://www.tdi-plc.com/ They won't work out any cheaper though anyway I would doubt - 19 hours is probably about the right time to strip, check and re-assemble if it is the cam/follower causing the issue. You need to take the steps above to eliminate other possibilities first a) change the oil to a high-quality synthetic (as above) and review follow the TSB for fuel damper and review - any competent local outfit can carry out this TSB for you and eliminate it as the cause at least. Whilst there, ask them for a diagnosis c) Travel to TDI for a diagnosis is a possibility I guess Quote Link to comment Share on other sites More sharing options...
barryda Posted February 7, 2008 Author Share Posted February 7, 2008 Ok thanks, also what about an engine flush ? .. to clear out any rubbish ?? .... I am going to get the oil filter and oil changed ... lok at the fuel damper .. and invetigate TDI for diagnosis ... Will I cause more damage by driving the car ? Thanks for all your help.. Barry Quote Link to comment Share on other sites More sharing options...
