wilo Posted August 19, 2016 Share Posted August 19, 2016 (edited) does any one know if there are any single mass clutch kits for a 2004 DE at reasonable prices . looked on ebay but cheapest i can find is +£800 . was hoping to find something in the £400 bracket as i have brakes and plenum spacer to buy to . also are there any company's on here that could supply all the parts i require . needing ..... 4 piece clutch kit (preferably single mass front and rear RED stuff pads hand brake shoes vented and groved rear disks (black) plenum spacer Edited August 19, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 19, 2016 Share Posted August 19, 2016 PM on the way Quote Link to comment Share on other sites More sharing options...
wilo Posted August 20, 2016 Author Share Posted August 20, 2016 PM on the way replied Quote Link to comment Share on other sites More sharing options...
evest Posted August 20, 2016 Share Posted August 20, 2016 I may be wrong mate but I believe that 'black' discs do not stay black once the coating has worn off. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 20, 2016 Share Posted August 20, 2016 not called single mass really, but solid flywheel Quote Link to comment Share on other sites More sharing options...
wilo Posted August 20, 2016 Author Share Posted August 20, 2016 I may be wrong mate but I believe that 'black' discs do not stay black once the coating has worn off. thanks for heads up ill double check Quote Link to comment Share on other sites More sharing options...
wilo Posted August 20, 2016 Author Share Posted August 20, 2016 not called single mass really, but solid flywheel lol ...I'm still learning mate . Quote Link to comment Share on other sites More sharing options...
wilo Posted August 20, 2016 Author Share Posted August 20, 2016 looks like Adrian can supply most parts i need with a difference of hawk pads from the red stuff i posted required. now the hawk are more expensive but ultra low dust like the redstuff ....so is worth the extra money for hawk pads bearing in mind im not tracking the car but simply want low dust due to having white alloys . Quote Link to comment Share on other sites More sharing options...
JimF Posted August 20, 2016 Share Posted August 20, 2016 Slight sidetrack but rather than low dust pads if you treated your white wheels with a specialist coating or something like Gtechniq Oracle (I think it's called) then a rinse with a hose would get your dust off. 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 20, 2016 Share Posted August 20, 2016 Slight sidetrack but rather than low dust pads if you treated your white wheels with a specialist coating or something like Gtechniq Oracle (I think it's called) then a rinse with a hose would get your dust off. Good advice! 1 Quote Link to comment Share on other sites More sharing options...
JimF Posted August 20, 2016 Share Posted August 20, 2016 Turns out its C5 not Oracle! http://gtechniq.com/products/auto/perfect/exterior/paint/c5-wheel-armour Quote Link to comment Share on other sites More sharing options...
Adam B Posted August 23, 2016 Share Posted August 23, 2016 (edited) I`m running hawk pads, there is far less dust than oem but they are not dustless by any means. Just so your aware clutch kit I`m currently running: http://www.350z-uk.c...nc-smf-350z-de/ Edited August 23, 2016 by Adam B Quote Link to comment Share on other sites More sharing options...
wilo Posted August 23, 2016 Author Share Posted August 23, 2016 (edited) I`m running hawk pads, there is far less dust than oem but they are not dustless by any means. Just so your aware clutch kit I`m currently running: http://www.350z-uk.c...nc-smf-350z-de/ thanks for the headsup Adam.also nice clutch kit but slightly out of budget due to all the other bits needed. also needing both side windows now as mine are badly scratched so the list is growing. i may rethink on the hawk pads and go for red stuff depending on there braking ability compared to hawk and oem. iv still yet to order any of the parts and holding off till im sure im getting the right parts needed . Edited August 23, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
