rich9001 Posted August 18, 2016 Share Posted August 18, 2016 (edited) Hi there, You guessed it, its MOT time and it failed, surprisingly though, it was the headlight beam pattern which was the problem! The passenger side beam isn't giving off the right pattern, apparently it looks like a non-uk assembly has been put in the passenger side. So i'm hunting for a UK spec passenger side headlight assembly. From previous posts someone else has been pointed in the direction of Zamanalex and Emperor tuning, but not sure they have any. Any and all help appreciated! Thanks. Edited August 19, 2016 by rich9001 Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted August 18, 2016 Share Posted August 18, 2016 Mine failed one year because the beams were too low. The next year it failed because the beams were too high. Very strange stuff! Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 18, 2016 Share Posted August 18, 2016 Can you get a photo of the beam pattern against a wall or something? Quote Link to comment Share on other sites More sharing options...
Gudzy Posted August 19, 2016 Share Posted August 19, 2016 Strange, that headlight was on the last couple of years when the MOT was done and no mention of it then. The passenger side is a replacement as the old one was scratched before I got it and letting in water which caused it to fail. Quote Link to comment Share on other sites More sharing options...
rich9001 Posted August 19, 2016 Author Share Posted August 19, 2016 Can you get a photo of the beam pattern against a wall or something? Yeah i'll try sort one out tonight. Quote Link to comment Share on other sites More sharing options...
rich9001 Posted August 19, 2016 Author Share Posted August 19, 2016 Strange, that headlight was on the last couple of years when the MOT was done and no mention of it then. The passenger side is a replacement as the old one was scratched before I got it and letting in water which caused it to fail. Hi Tom! I know, that's what I thought, seems strange that its all of a sudden wrong. Andy (Atkin's in Malton), said that it could be possible that it's a non-uk part which is why it isn't giving off the right pattern. I know its asking alot but I don't suppose you know where you got it from? There may be a receipt in the folder (its at home and i'm at work so i can't check), don't worry if you can't remember, i'll be having a look when I get home. Quote Link to comment Share on other sites More sharing options...
Gudzy Posted August 19, 2016 Share Posted August 19, 2016 Got it from eBay a couple of years ago, I bought a pair and sold the other one on here to someone that had had a smash. I can't see the description as the listing is over 90 days old unfortunately. Quote Link to comment Share on other sites More sharing options...
rich9001 Posted August 19, 2016 Author Share Posted August 19, 2016 Not to worry, thanks for checking anyway. i'll take a look tonight Quote Link to comment Share on other sites More sharing options...
HaydnH Posted August 19, 2016 Share Posted August 19, 2016 Wouldn't there be a part number on the assembly you can check to see if it's UK/Jap/Other? Quote Link to comment Share on other sites More sharing options...
R35LEE Posted August 19, 2016 Share Posted August 19, 2016 I may have a UK spec one, PM sent Quote Link to comment Share on other sites More sharing options...
rich9001 Posted August 20, 2016 Author Share Posted August 20, 2016 Finally been able to get out and have a look myself, you can see the pattern is the wrong way round. The cut off for the passenger side is slanted the the left, it should be the other way around. I've also attached an example. Also, still on the look out for a new headlight, Lee doesn't want to answer his phone Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 21, 2016 Share Posted August 21, 2016 Yup, definitely wrong. Must have been a US or EU replacement. Quote Link to comment Share on other sites More sharing options...
