Flex Posted August 17, 2016 Share Posted August 17, 2016 Firstly, the spelling mistake was so you'd come in. The Zed is the only car without one at the moment. Skyline has a small leak but level doesnt change and it's like a drop probably like once everytime it's taken out. At 21 years old (the car not me ) do you think I should worry or just accept it. 2 Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 17, 2016 Share Posted August 17, 2016 I only came here to correct your spelling Where is it leaking from? If it's somewhere that could suddenly get catastrophically worse then I'd sort it ASAP, if it's just a nibble from somewhere unimportant then I'd leave it. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 17, 2016 Share Posted August 17, 2016 Firstly, the spelling mistake was so you'd come in ..................... you got me too ! ... it's my job 1 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 17, 2016 Share Posted August 17, 2016 Used to like leeks but not in oil. Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 17, 2016 Share Posted August 17, 2016 Olive oil? Quote Link to comment Share on other sites More sharing options...
GMballistic Posted August 17, 2016 Share Posted August 17, 2016 Skyline has a small leak but level doesnt change and it's like a drop probably like once everytime it's taken out. At 21 years old (the car not me ) do you think I should worry or just accept it. As Dan said do you know where the leak is coming from? Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 17, 2016 Share Posted August 17, 2016 Just keep an eye on it, if it gets worse then that's when to consider options. No doubt it will get worse, just a question of when I guess so would be good to know where it's coming from. Quote Link to comment Share on other sites More sharing options...
Flex Posted August 18, 2016 Author Share Posted August 18, 2016 Somewhere on the engine lol. I'm going to get her a good seeing to over the winter so will know more then. Like I said it's minuscule and oil level not even moved since last service. Although only done about 1500 miles max. The Zed would have probably used a litre over that distance! Quote Link to comment Share on other sites More sharing options...
coldel Posted August 18, 2016 Share Posted August 18, 2016 Give it a good blast mate with some degreaser so its all cleaned up, stick some cardboard under the car and see how it goes when its parked up - you can see how much is dripping out, and get a view on where its coming from. 1 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted August 19, 2016 Share Posted August 19, 2016 What he said ^^ just start from the top down after a good clean to see if you can identify the offending article. Quote Link to comment Share on other sites More sharing options...
