dkeenan87 Posted August 16, 2016 Share Posted August 16, 2016 Hi, First time post having been a 350Z owner for a few months! I've been throwing up a P1167 error code lately. I have reset it a few times and it stays off for a while before eventually coming back on. Car is running fine but would like to get it sorted. Standard exhaust system fitted. I can see its an O2 sensor and I'm guessing it's probably dodgy. From my research it looks like this code is the rear one but does anyone know which one it is? Also, does anyone know how expensive they are?! Thanks, Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 16, 2016 Share Posted August 16, 2016 (edited) Bank 2 rear O2 sensor, best to fit OEM and not aftermarket. No harm in replacing the sensor but a proper diagnostic would be advised. Check connector to make sure it's sound as a failure could be electrical as the wires are exposed to the elements under the car. Worst case scenario maybe a failed Cat. I replaced all of mine and still had the codes coming up so replaced the standard Cats with HFCS. Again after that the rear sensors played up periodically so eventually an Uprev map deleted them completely. I can't remember what I paid without trawling through my receipts but one side was more expensive than the other Edited August 16, 2016 by Zeezeebaba 1 Quote Link to comment Share on other sites More sharing options...
dkeenan87 Posted August 16, 2016 Author Share Posted August 16, 2016 Thanks for this. Is Bank 2 the drivers side or the passenger side do you know. Hoping it isn't the cat, flew through an MOT a couple of months ago (and think the light was coming on before then). Will check the wiring this weekend though Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 16, 2016 Share Posted August 16, 2016 Passenger side I believe is bank 2 Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted August 18, 2016 Share Posted August 18, 2016 Bank 2 is definitely passenger side. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted November 29, 2016 Share Posted November 29, 2016 Did you get this sorted OP? Quote Link to comment Share on other sites More sharing options...
