RobPhoboS Posted March 26, 2017 Share Posted March 26, 2017 3.9 for me too but not quite yet :/ 1 Quote Link to comment Share on other sites More sharing options...
GodISmE Posted March 28, 2017 Share Posted March 28, 2017 Butcher, is this the Koyo radiator you got? My top fixings have snapped during last weekend's track day so I might as well replace the whole radiator to help with cooling during those hot summer days. https://www.z1motorsports.com/cooling/koyo/07-08-350z-hr-koyo-upgraded-radiator-p-5133.html Quote Link to comment Share on other sites More sharing options...
350Butcher Posted March 28, 2017 Author Share Posted March 28, 2017 Makes sense to install the Koyo rad then. Its a quality bit of kit and the fit is absolutely spot on. Part no.V2999 is the one you want, thats the 36mm core competition rad. Pics of mine are on page 1 Quote Link to comment Share on other sites More sharing options...
GodISmE Posted March 30, 2017 Share Posted March 30, 2017 Thanks. You mentioned that the billet gears for the oil pump costed 200 pounds. Did you buy them in the UK? Quote Link to comment Share on other sites More sharing options...
350Butcher Posted March 30, 2017 Author Share Posted March 30, 2017 Thanks. You mentioned that the billet gears for the oil pump costed 200 pounds. Did you buy them in the UK? I wish it was £200! Here is a link to where I ordered mine http://www.boundarypumps.com/nissan/nissan-oil-pump-gears Quote Link to comment Share on other sites More sharing options...
GodISmE Posted March 30, 2017 Share Posted March 30, 2017 (edited) Oh yeah, I was right thinking it was the Boundary gears. I will probably replace them too when fixing the gallery gaskets after seeing this: https://scontent-ams...af5&oe=595DD12A https://www.facebook...490815252516241 Edited March 30, 2017 by GodISmE Quote Link to comment Share on other sites More sharing options...
350Butcher Posted March 31, 2017 Author Share Posted March 31, 2017 Don't let me stop you but if you're leaving the engine stock then it won't be worth revving over 6800rpm as it doesn't make any power over that and the standard gears are plenty up to the job for that. The standard gears have a square profile on one face of the outer pump gear and when revved higher this becomes a weak spot and is the first place to go as a result (you'll see that in the pic you attached). I think all the horror pics to see of the gears in pieces aren't from standard cars and don't tell the full story. That said no harm in building in strength and reliability either. Quote Link to comment Share on other sites More sharing options...
GodISmE Posted April 2, 2017 Share Posted April 2, 2017 Yeah but I've already decided to do cams too - probably Tomei 272 / 10,8. I want to do cams and the oil pump gears while replacing the gallery gaskets. Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 2, 2017 Author Share Posted April 2, 2017 Ahh thought you said you were gonna leave the engine stock for a while. In that case it makes sense, the stock design does have that weak spot and like me I'm sure you don't want to be worried about it breaking up instead of enjoying driving the car. Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 2, 2017 Author Share Posted April 2, 2017 Bit of an update! So I went down to Surrey to collect the heads on Wednesday, porting work and cnc valve seat cutting all finished. Stayed down at the shop Thursday/Friday to get the all the valves lapped in and the valve clearances set.........building up the heads, measuring clearances, stripping back down, grinding valves, rebuild, recheck clearances........proper ball ache work but all done now! Got home to find this, which was good news too. There's a few pics now! First up is how much meat has come out of the heads from the porting Heads all washed out, oil and water ways blown through and left to dry in the sun A few pics of the head work. First pic is one sent through from Steve showing the inlet cnc seat profile vs std. Then a few of the finished job, inlet and exhaust port work, The shaping has removed the "wall" between where the port splits to the 2 valves and also the short side on the exhaust has now got a far straighter run from the big angle it has as stock. So back at home and heads all washed it was actually time to start putting stuff together!! Got to say its felt like ages so I've really enjoyed making some progress with it..............so much so I forgot to take many pics! Who knew oak furniture land made build benches! and the new tomei springs vs stock.......trick oval wire thats allows for lower height at full compression due to the increased lift Heads fully assembled, time to grab the manifolds from the loft and get out in the garage! Had to get my new engine mounts in and the manifolds in place before heads went on Spin in the ARP studs and get the Cosworth gaskets in place then drop the heads back on torque them down and get those long tube manifolds bolted up! And to finish up this weekends work I got the cams laid in (nice of tomei to remind you of what you've ordered), got the oil gallery gaskets fitted and started the horrible part of siliconing the parts together which I must say after being rather apprehensive of this and the fact this engine uses a lot of the stuff it really isn't as bad as I thought it might be..........I did make life much easier by getting some M6 studding and cutting off a couple of 6" long lengths to act as a guide to slide the rear timing chain cover towards the engine so to get it on perfect first time and not drag any of the silicone off while trying the locate the factory dowels........worked a treat! Next up to start putting the timing chain on! 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 2, 2017 Share Posted April 2, 2017 Sooo awesome ! What made you choose Tomei over JWT or BC ? We have the same engine mounts, they are really good and you can feel the positive effect from them Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 3, 2017 Author Share Posted April 3, 2017 Cheers!! Not sure BC do cams for the HR but didn't really think to look at them anyway. There's a bit more info out there on the tomei cams so it was a bit of a better trodden route........not always the best but you know more what you're gonna get. The tomeis I thought were a better spec than the JWT cams which have less duration and higher lift, which I thought just gives less time to take advantage of the scavenge I'll get from the new manifolds to draw in air/fuel charge in to the cylinders. Looking forward to getting on track with the new mounts in, vibratechics have also made me a one off gearbox mount so hopefully I'll have lots of praise for that and it'll be available to all soon. Hoping to firm it up but without the downside of all the vibration and noise coming in the car from the ones currently available 1 Quote Link to comment Share on other sites More sharing options...
GodISmE Posted April 3, 2017 Share Posted April 3, 2017 (edited) I know your mileage is relatively low but looking at the timing gear while having it open, what parts do you think would be worth replacing at 100k miles when doing the gallery gaskets? Edited April 3, 2017 by GodISmE Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 3, 2017 Author Share Posted April 3, 2017 I know your mileage is relatively low but looking at the timing gear while having it open, what parts do you think would be worth replacing at 100k miles when doing the gallery gaskets? Its really up to you, could probably change nothing else other than the obvious gaskets and orings. Not sure if there is a quoted time for changing the chain, sprockets and water pump etc but if its been regularly serviced then I'm guessing they will still be OK but worth checking for signs of wear.............will be pricey if it does all want replacing though! I'd say just get the gaskets changed as they need changing, that gets you up and running again, then when you're ready to do your full build you'll probably want to change everything if its at 100k+ miles Quote Link to comment Share on other sites More sharing options...
GodISmE Posted April 4, 2017 Share Posted April 4, 2017 I think I'll just give up spending hours and hours on the internet trying to figure out what to do next and how to do it and I'll just follow everything you do. Seriously! Just out of curiosity, do you have any background in car mechanics or is it just your hobby? Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 4, 2017 Share Posted April 4, 2017 Some good progress there mate Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 4, 2017 Author Share Posted April 4, 2017 Yeah there's a ton of info on the net and you've got to sieve through fact and fiction which is not always easy! You might wanna see what results I get first!! But that's why I thought I'd share this build so people can see what I've done and what bits I've used and if it's helpful to others then all the better Never been a mechanic, just a heating engineer!! I've been lucky to have really good people who are now good friends to ask questions to, learn from and get proper sound advise from since my first engine build about 17 years ago!! Just love doing it and all spannering and of course the driving too!! Started with my mk2 Astra GTE with a C20LET turbo full build, dry sumped 275bhp and since the. I've fully rebuilt Evo 5 420bhp Impreza 350bhp (friends car) Civic Vti B16 190bhp (friends car) And now part built 350z ---bhp 1 Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 4, 2017 Author Share Posted April 4, 2017 Some good progress there mate Thanks! It's coming together, can't wait to fire it up and go for a drive now the suns coming out a bit Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 9, 2017 Author Share Posted April 9, 2017 Bit of an update..... Got the car timed up and I must say the system nissan have with the chain using coloured links lined up with ID marks on the sprockets is a touch of genius! After looking a bit frightening with the 3xchains its so easy and visually so simple to see when everything is in place Then back in with my M6 studding ready to fit the front cover.............load more silicone and slide it back into place Forgot to take many pics after this as I was just cracking on with it but made really good progress. Sump was installed, rocker covers fitted, wiring loom and auxiliarys installed. This then meant the subframe could then get bolted back up and the engine actually sit on its new mounts for the first time! The last part to collect is the intake manifold which I'll have next weekend, so its looking like I might possibly turn the key on it over easter weekend! Not driven the car since getting back from Germany in September so it'll be nice to have it up and running again. This is as it stands.........looking like its got an engine in again 2 Quote Link to comment Share on other sites More sharing options...
GodISmE Posted April 9, 2017 Share Posted April 9, 2017 Nice! Can't wait to see and hear it run now with all these mods! Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 10, 2017 Share Posted April 10, 2017 Excellent news Try and get us a vid of the first startup Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 10, 2017 Author Share Posted April 10, 2017 Won't be the first start up but once I've finished the cam break in I'll post up a before and after sound vid on idle It's the pull and noise I'm looking forward to from 5-8k rpm!!! Quote Link to comment Share on other sites More sharing options...
WillisRR Posted April 11, 2017 Share Posted April 11, 2017 (edited) WOW! This thing really has gone wild hasn't it haha! Mega effort and love that you are getting properly stuck in. Cant wait to see it built up mate. Be great to get on a track day with some of us 350 lot over summer? Edited April 11, 2017 by WillisRR 1 Quote Link to comment Share on other sites More sharing options...
350Butcher Posted April 11, 2017 Author Share Posted April 11, 2017 WOW! This thing really has gone wild hasn't it haha! Mega effort and love that you are getting properly stuck in. Cant wait to see it built up mate. Be great to get on a track day with some of us 350 lot over summer? Cheers..........yeah trying to get on with it.......its just been turned over on the key till oil pressure...... annoying just waiting to collect the inlet manifold this weekend, fit the plugs in and fire it up! Me too, been a long time working on it and really looking forward to driving it again. Funny you say that, I was gonna suggest just that! There seems to be a few of us 350z owners who do track their cars and it would be really good to get a few Z's out on track together. The only time I've seen 350's and 370's at tracks they've been parked up all day while the owners drive some banger that goes slower and handles worse than the car they drove there in........don't understand it, seems like such a shame as the Zed is such a capable and rewarding car on track.......each to their own of course 2 Quote Link to comment Share on other sites More sharing options...
WillisRR Posted April 12, 2017 Share Posted April 12, 2017 (edited) Excellent mate, not much to do now!! Yes! Let's get on it! Totally agree! Maybe it's a compliment in many ways that people deem them too nice to batter about on track . Edited April 12, 2017 by WillisRR Quote Link to comment Share on other sites More sharing options...
