Chris141084 Posted August 14, 2016 Share Posted August 14, 2016 Can anyone recommend a good glass scratch removal product/method for deep ish scratches? Quote Link to comment Share on other sites More sharing options...
Ricey Posted August 14, 2016 Share Posted August 14, 2016 Spark plug through the glass and call your insurer. Seriously mate polishing glass is extremely difficult. Sent from my SM-G925F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 14, 2016 Share Posted August 14, 2016 Curtting compound and a machine polisher is your best bet otherwise replace as previously mentioned. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted August 14, 2016 Share Posted August 14, 2016 if its a deep scratch - not a hope in hell - however some light scuffing might be removed with a polisher and some cerium oxide Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted August 14, 2016 Share Posted August 14, 2016 are the scratches in the the door windows and vertical? its a known issue, don't think i've heard of anyone being able to get them out Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 14, 2016 Share Posted August 14, 2016 Cutting compound won't do anything to glass beyond getting it quite clean. You'll need cerium oxide and rayon pads with a machine polisher to make any impact. As Ricey alluded to, replace the glass or live with it. It's not worth the time, effort or expense of trying to fix. Quote Link to comment Share on other sites More sharing options...
Chris141084 Posted August 14, 2016 Author Share Posted August 14, 2016 Thanks for the advice guys, they were vertical but really bad. Just bought a security nd hand window, should be able to see through this one :-) Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 14, 2016 Share Posted August 14, 2016 When you do fit the new glass, give the window mechanism a quick clean. The scratches are caused by the dirt on the window getting trapped on the brushes, so be sure to give them a clean otherwise you'll have the same problem again in future. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 15, 2016 Share Posted August 15, 2016 I have got scratches out of glass with paint cutting compound and a buffer on several occasions. Quote Link to comment Share on other sites More sharing options...
