LDUNKZ18 Posted August 13, 2016 Share Posted August 13, 2016 does anyone know all there is to know about air compressors? i have ltsuk 270litre 3hp single phase air compressor.. just changed the oil and put a new belt on as it kept cutting out but its now doing it more often than before.. i think it could be an electrical issue. it will come on and work but after 30 seconds to maybe 2 minutes it will cut out and trip the reset switch. press the reset button and it works again then cuts out. i thought the old belt was slipping but it seems worse with the new belt. any ideas what it could be? Quote Link to comment Share on other sites More sharing options...
leonk Posted August 13, 2016 Share Posted August 13, 2016 (edited) It could be the capacitor, mine did the same thing. They get too hot and melt. It's a tubular thing about the size of the cardboard bit of a toilet roll. Mine was caused by running the compressor too much shot blasting. Edited August 13, 2016 by leonk Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted August 13, 2016 Author Share Posted August 13, 2016 It could be the capacitor, mine did the same thing. They get too hot and melt. It's a tubular thing about the size of the cardboard bit of a toilet roll. Mine was caused by running the compressor too much shot blasting. yeah the more im reading online the more i think this is the issue it must be on its way out. i use it for spraying so gets used for 2 maybe 3 hours straight not a surprise its maybe fried it with the heat. Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted August 13, 2016 Share Posted August 13, 2016 Quite often when the capacitor is shot, it looks all expanded ( bloated out ) if u know what I mean ie no longer a nice cylindrical shape with flat ends. Quote Link to comment Share on other sites More sharing options...
leonk Posted August 13, 2016 Share Posted August 13, 2016 Mine had its innards oozing out. The good thing is they aren't too dear and easy to replace. Just make sure you change it like for like as they have different ratings. Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted August 13, 2016 Author Share Posted August 13, 2016 it actually exploded once before and got one for nothing after emailing the company. hopefully i will hear back from them monday and they will know what could be the issue and can sort it fairly cheap Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted August 20, 2016 Author Share Posted August 20, 2016 Got a new capacitors but it has 2 red wires instead of being like the old one that has 1 brown and 1 blue. Any ideas? Quote Link to comment Share on other sites More sharing options...
