Parts clear out Part 2
Daryl
Got some more bits to add for sale after my beloved Zed went to its new owner.
All based in Milton Keynes, and prices are for collection. P&P is at buyers cost.
First up, an individual Invidia Rolled tip exhaust finisher. I ended up having to buy another pair as i 'lost' one. These are not cheap to buy, and generally only come in pairs. Spent a fair while glatting and polishing this, so its pretty shiny. £50
Original DE airbox, with original Nissan filter. Filter looks hardly used, and the box itself is in good condition, no cracks etc. Great if you want to do the Rev Up mod to it, or you want to return to stock. £25
Original DE intake pipe. Does not come with the MAF im afraid, but in good condition. £15
Pair of stock tail lights. Should have put these back on my Zed and sold the Facelift ones on their own. Dont be a fool like me, buy these! All working with bulbs etc. One locating lug is snapped, but does not affect fitment, if anything, it aids it. £70 the pair
Drivers side window switch. All present and correct, full working order. £40
If you fancy a change or have lost an existing one, have a Zed badge to replace the burger Nissan ones.
Got it from the US at great cost. Has a slight mark at the bottom, which iv taken a photo of. £25
Have a front axle set of DS2500 pads for the Brembo calipers. Only changed as fitted brand new with new discs. Plenty of meat on them, atleast one track day if not more. £30
What I believe to be standard front reflectors. Great if you wanted to put LED's in or play around with them.
Never got around to fitting this Kinetix plenum. I modified it to remove the large Kinetix script on the top, and smoothed out as best i could all the large join lines on the inside face to improve airflow. Has been painted in cackle finish black paint. Just needs a gasket to mount to the top of the engine. If you dont know about these they are pretty rare, and they do the job of a plenum spacer, as well as looking alot better, as well as having the clearance for the strut brace. £100
http://www.kinetixracing.com/kinetix_350Z_and_G35_intake_plenum.aspx
Standard Dual Mass Flywheel. Came out my car at 55k, and has been in storage since. £50
Standard front number plate holder. £10
Full set of standard wheel nuts with locking wheel nuts and key. Comes with the extra nuts never fitted. £15
Standard front splitter/deflector. Not perfect but perfectly usable. £25
Never got round to fitting this. Its a Cookbot wingmirror mod to get the wing mirrors to retract when you lock the car. Fitting instructions are on the site i believe. £20
  • 3 weeks later...
Hi mate, what size are the wheel nuts? Are they 19mm? Reason is my wheels have very small clearance for a socket to fit in so 19mm are the biggest I can fit in there. I will probably take them if they are 19mm as I don't like the wheel nuts that are on mine and they are mostly all very close to being rounded so could do with replacements.
Cheers
Rikki
Ill take them mate in that case. I am passing through MK in about 1hr but that may be too short notice. I will also be passing through MK again a couple times on Sunday in the afternoon between 1pm and 3pm if any of those times suit for collection?
  • 1 month later...
  • 2 months later...
