Undertray bolt locations
GizmoGold
Does anyone have an image of where the bolts are for the undertray to be secured? Mines currently cable tied up, but droops and I want to replace with a metal one.
But I have no bolt holes in the centre of the car, so I'm guessing they've snapped off in the past and I'll need to drill them out. A photo of the hole locations will make it easy for me to find out what I need to do :teeth:
I'm also going to be plastic welding the tabs on the front bumper as they've all snapped off =/
Thanks, I've already done a google search but I'm hoping someone has instructions to show where the bolts are when the undertray is removed. I've seen an image before with the areas circled but can't find it again.
Sorry but that is the best that I can do.
Why don't you offer your tray up to the body underside as that will give you an over view of where the bolts go.
Check this post, shows you all the holes on the undertray, it follows the OEM holes :)
http://www.350z-uk.com/topic/97969-torqen-350z-370z-torqen-undertrays/
http://www.350z-uk.com/topic/97969-torqen-350z-370z-torqen-undertrays/page__st__80#entry1487114
http://www.350z-uk.com/topic/97969-torqen-350z-370z-torqen-undertrays/page__st__140#entry1508586
