wez370 Posted August 11, 2016 Share Posted August 11, 2016 Has anyone else experienced a sound from underneath the car (hard to pinpoint a direction) that sounds almost like a click when you brake and put a bit more pressure on just before you come to a standstill. It only clicks once just before the car stops moving and doesnt happen at all during normal driving. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 11, 2016 Share Posted August 11, 2016 Sounds like clicky axle Don't panic It's a case of a bit of lube around the splines 1 Quote Link to comment Share on other sites More sharing options...
wez370 Posted August 11, 2016 Author Share Posted August 11, 2016 On 11/08/2016 at 07:32, nissanman312 said: Sounds like clicky axle Don't panic It's a case of a bit of lube around the splines Do i need to take apart the entire rear assembly to get to sort this? Quote Link to comment Share on other sites More sharing options...
coldel Posted August 11, 2016 Share Posted August 11, 2016 Have a search on the forum, there is a guide somewhere for doing this... 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted August 11, 2016 Share Posted August 11, 2016 Here you go --> http://www.350z-uk.com/topic/57807-clicking-axle-noise-solved-try-this-first/ 1 Quote Link to comment Share on other sites More sharing options...
coldel Posted August 11, 2016 Share Posted August 11, 2016 Just noticed this is in the 370z section, do you have a 370 that is clicking? Wasn't aware the problem carried through from the 350z? So maybe it is something else? 1 Quote Link to comment Share on other sites More sharing options...
R35LEE Posted August 11, 2016 Share Posted August 11, 2016 Check your drop links, 99% of the time on a 370z they are the cause of clicking and clunking 1 Quote Link to comment Share on other sites More sharing options...
wez370 Posted August 11, 2016 Author Share Posted August 11, 2016 On 11/08/2016 at 09:15, coldel said: Just noticed this is in the 370z section, do you have a 370 that is clicking? Wasn't aware the problem carried through from the 350z? So maybe it is something else? yeah my 370 is doing a single click just before the car stops moving. Quote Link to comment Share on other sites More sharing options...
