Lexx Posted February 4, 2008 Share Posted February 4, 2008 As some of you know, I work in the Merchant Navy. And thus go away for 3 months at a time. The car will be getting garaged for that period. Aside from chocking the wheels, leaving the handbrake off, disconecting the battery, and covering the car. Is there anything else I should be doing specific to a Zed? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 4, 2008 Share Posted February 4, 2008 It was the case that when battery is disconnected the windows suddenly dropped. Don't know if that is the case on MY07. So worth checking that this doesn't happen or it could me messy with broken glass everywhere. Quote Link to comment Share on other sites More sharing options...
Lexx Posted February 4, 2008 Author Share Posted February 4, 2008 Cheers for that. Will investigate further tomorrow when it's light Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 4, 2008 Share Posted February 4, 2008 just found this in the service manual but like I said earlier, don't know if this is the case with MY07 PRECAUTIONS PFP:00001 Precautions for Battery Service AKS003RD This vehicle is equipped with the automatic window adjusting function. When a door is opened, the window automatically lowers slightly to avoid contact between the window and the side roof panel. After the door is closed, the window will automatically raise slightly. On vehicles equipped with the automatic window adjusting function, lower both the driver and front passenger side windows before disconnecting the battery cables. This will prevent interference between the side window and the roof panel when either door is opened/closed. CAUTION: After the battery cables are disconnected, do not open/close the driver and/or front passenger door with the window in the full up position. The automatic window adjusting function will not work and the side roof panel may be damaged. Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 4, 2008 Share Posted February 4, 2008 Drain the fuel. I wouldn't want 3-month old petrol to be in there when I drove it again after that time. Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 4, 2008 Share Posted February 4, 2008 Ekona said: Drain the fuel. I wouldn't want 3-month old petrol to be in there when I drove it again after that time. No dont drain the fuel , fill it right to the brim this way you wont leave an air gap , besides which I'm sure the Zed doesnt have a drain plug on the fuel system.. Fuel wont go bad in 3 months if you do this Also pump up your tyres hard so if they do leak slightly with standing they wont damage the sidewalls.. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted February 4, 2008 Share Posted February 4, 2008 Plug the exhaust with rags to seal the engine from moisture in the air (presume the exhaust is SS so no probs there!) Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 4, 2008 Share Posted February 4, 2008 lomoto said: Ekona said: Drain the fuel. I wouldn't want 3-month old petrol to be in there when I drove it again after that time. No dont drain the fuel , fill it right to the brim this way you wont leave an air gap , besides which I'm sure the Zed doesnt have a drain plug on the fuel system.. Fuel wont go bad in 3 months if you do this But surely you'll still have air in there? I'll admit I'm no expert on the Z and its fuel system, but surely there's some kind of vent that allows fumes to escape and not build up in there, meaning that the tank isn't fully airtight? Either way, I'd not take the risk. Maybe drain is the wrong word. Burn it by driving instead! Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 4, 2008 Share Posted February 4, 2008 Ekona said: lomoto said: Ekona said: Drain the fuel. I wouldn't want 3-month old petrol to be in there when I drove it again after that time. No dont drain the fuel , fill it right to the brim this way you wont leave an air gap , besides which I'm sure the Zed doesnt have a drain plug on the fuel system.. Fuel wont go bad in 3 months if you do this But surely you'll still have air in there? I'll admit I'm no expert on the Z and its fuel system, but surely there's some kind of vent that allows fumes to escape and not build up in there, meaning that the tank isn't fully airtight? Either way, I'd not take the risk. Maybe drain is the wrong word. Burn it by driving instead! No you'll always have a small amount of fuel left in the bottom of the tank that will go bad, three months is nothing really, certainly not long enough for a full tank of petrol to go off, I know mines been laid up since October ( in fact since the last Wales run out whenever that was ) Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 4, 2008 Share Posted February 4, 2008 Heh, in that case I humbly bow to your superior knowledge! Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 4, 2008 Share Posted February 4, 2008 Ekona said: Heh, in that case I humbly bow to your superior knowledge! no everyone has different ideas wont be too long now before mine can come out to play Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 4, 2008 Share Posted February 4, 2008 God I'd kill for a garage that big... I've got 20mm gap at the front of the car and just 15mm at the back in mine. Beautiful cover that, custom made? Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 4, 2008 Share Posted February 4, 2008 Ekona said: God I'd kill for a garage that big... I've got 20mm gap at the front of the car and just 15mm at the back in mine. Beautiful cover that, custom made? it actually came with the car when I bought it off the first owner , i think it's a genuine Nissan item it has the Z logo on the bonnet Quote Link to comment Share on other sites More sharing options...
Beavis Posted February 4, 2008 Share Posted February 4, 2008 lomoto said: Ekona said: lomoto said: Ekona said: Drain the fuel. I wouldn't want 3-month old petrol to be in there when I drove it again after that time. No dont drain the fuel , fill it right to the brim this way you wont leave an air gap , besides which I'm sure the Zed doesnt have a drain plug on the fuel system.. Fuel wont go bad in 3 months if you do this But surely you'll still have air in there? I'll admit I'm no expert on the Z and its fuel system, but surely there's some kind of vent that allows fumes to escape and not build up in there, meaning that the tank isn't fully airtight? Either way, I'd not take the risk. Maybe drain is the wrong word. Burn it by driving instead! No you'll always have a small amount of fuel left in the bottom of the tank that will go bad, three months is nothing really, certainly not long enough for a full tank of petrol to go off, I know mines been laid up since October ( in fact since the last Wales run out whenever that was ) +1 Yep Tim is right, fill her up, also stops any chance of condensation building up inside the tank. Quote Link to comment Share on other sites More sharing options...
MartinGT Posted February 5, 2008 Share Posted February 5, 2008 i couldnt deal with a garage that small the aerial bit of that cover looks slightly disturbing. Quote Link to comment Share on other sites More sharing options...
bronzee Posted February 5, 2008 Share Posted February 5, 2008 MartinGT said: i couldnt deal with a garage that small the aerial bit of that cover looks slightly disturbing. Bigger is better. Oh, and yes make sure you leave the petrol tank full. Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted February 5, 2008 Share Posted February 5, 2008 M13KYF said: just found this in the service manual but like I said earlier, don't know if this is the case with MY07 It should be the case with the MY07 since there is no frame around the door windows, and dropping the window when opening the door is the only way to open it without breaking the seal around the door. I think this might actually be the case for all cars which do not have a frame around the door window Quote Link to comment Share on other sites More sharing options...
Lexx Posted February 5, 2008 Author Share Posted February 5, 2008 Cheers guys. Windows down and a full tank of petrol it is! Quote Link to comment Share on other sites More sharing options...
