ZedGreg Posted August 4, 2016 Share Posted August 4, 2016 Morning boys! So the 350 has a click occuring....it seems to come after a bit of a journey so once everything has warmed up...essentially it clicks when i release the accelerator and then press it again so obviously the engine rock causes something to move direction...i understand this could either be the legendary clicky axle or the ARB drop links...any insight would be greatfully received! Sent from my SM-G928F using Tapatalk Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted August 18, 2016 Share Posted August 18, 2016 Check out YouTube as they have footage of both the clicky axles and knackered drop link, you'll know what your problem is when you view the footage. I thought clicky axles happened every time you pulled away or started to move in reverse. Quote Link to comment Share on other sites More sharing options...
S90_GWE Posted November 20, 2016 Share Posted November 20, 2016 My car developed the typical click when pulling away however my mechanic has suggested it is coming from the carbon prop shaft rather than the drive shafts. HAs anyone come across this? He said he experienced the same issue on his GT-R R35 and has changed the prop twice. Quote Link to comment Share on other sites More sharing options...
S90_GWE Posted November 20, 2016 Share Posted November 20, 2016 Should point out it's a 2006 pre-facelift with 24k miles Quote Link to comment Share on other sites More sharing options...
scobie140 Posted November 25, 2016 Share Posted November 25, 2016 Defo worth heckling your drop links. Mines developed a bad click/clunk from no where and there was minimum play but front drop links were the culprit. I was gutted as they had done less than 10k and we're white lines ones at £140 so didn't get much out of them Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
