Another starting problem , please help !
Samcharville
Hi all :)
Basically excuse my spelling
I brought a 350z 2 days ago and whilst I was there it was absolutely fine , started on the button every time
Got it home that day and left it until the morning. Took ages to start but eventually did
Now it takes from 2 - 10 times crank stop crank stop and eventually starts hot or cold
The way the car acts
When cranking before it eventually goes it stinks of fuel
Fuel pump primes
New battery
Runs faltlessly when driving ( little underpowered low revs but goes at about 4-5k
Idles sweet as no, misses or noises
Plugged it in to diagnostics came up with p0021 witch came up " bank 2 "A" cam position timing performance "
Changed that cps on bank 2, no difference
Cleaned out the valve timing solinoide and it fired quicker than normal ( might just be luck )
Thought I would ask here before changing the valve timing solinoide
Any one had this problem ? Thanks people
I honestly have no idea without checking your car out, however 30 minutes below the bonnet by an informed 350Z tech, should answer your question.
I would firstly be looking again at cam and crank position sensors.
Zmanalex knows his stuff....If you like me know almost nothing about the technical side of cars I would recommend you to get a good mechanic who knows about 350z! I learned it hard way 3 years ago,spent a lot before I met Sly (Kaizermotors).
Like with any sport car you need a reliable mechanic,if you know nothing yourself!
