Samcharville Posted July 26, 2016 Share Posted July 26, 2016 Hi all Basically excuse my spelling I brought a 350z 2 days ago and whilst I was there it was absolutely fine , started on the button every time Got it home that day and left it until the morning. Took ages to start but eventually did Now it takes from 2 - 10 times crank stop crank stop and eventually starts hot or cold The way the car acts When cranking before it eventually goes it stinks of fuel Fuel pump primes New battery Runs faltlessly when driving ( little underpowered low revs but goes at about 4-5k Idles sweet as no, misses or noises Plugged it in to diagnostics came up with p0021 witch came up " bank 2 "A" cam position timing performance " Changed that cps on bank 2, no difference Cleaned out the valve timing solinoide and it fired quicker than normal ( might just be luck ) Thought I would ask here before changing the valve timing solinoide Any one had this problem ? Thanks people Quote Link to comment Share on other sites More sharing options...
