88 Zed Posted July 24, 2016 Share Posted July 24, 2016 Hi all, I have a 2002 JDM import and my EML / VCD and slip light are making an apperence every now and then. Plugged it into the snap-on modus in work and got the following P0350- Ignition coil primary circuit problem. (In engine managment) C1109- battery voltage out of range. ( in ABS) C1130- Engine 1 fuel cut system fault (in ABS) Obviously there is a problem with one of the coils, but as the problem isn't constant (yet) I can't pin point exactly which one is at fault. I haven't got the cash to splash out on all 6 coils at the moment. My question is, will the faulty coil bring up faults in the ABS/ VDS system? I've drop tested the battery and tested the altanator charging rate etc and that's all fine. All 3 lights come on symbultainiously, cycle the ignition and only the EML remains (until I reset it with a scanner) Any pointers will be much appreciated! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 24, 2016 Share Posted July 24, 2016 Best to delete all the codes and start with a clean slate as some of the DTCs may be archived. If the fault is a coil pack then I would have thought that you would have a miss fire. Not just a case of a heavy right foot causing the lights ? How are your tyres and sizes ? Quote Link to comment Share on other sites More sharing options...
88 Zed Posted July 24, 2016 Author Share Posted July 24, 2016 Hi, yea I have erased everything and re scanned once they re appeared, same codes come back. I cant feel a misfire and all the data I can read from the scanner suggests that it's not misfiring (at least when I've been monitoring it anyway). My plan was to let it fail compleatly so I can find the faulty coil but it's thrown me off a bit with these codes from the ABS module. The codes have re appeared in slow moving traffic so I don't think it's due to any loss of traction although I have had issues with it interfering at speeds I wouldn't have thought it should be. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 24, 2016 Share Posted July 24, 2016 And the tyre condition and sizes ? Quote Link to comment Share on other sites More sharing options...
88 Zed Posted July 24, 2016 Author Share Posted July 24, 2016 225/45/18 Toyo proxys on the front and 245/45/18 kumho's on the rear with wheel spacers and lowering springs. I know this would cause over sensitive traction controll but it's never flagged a light up before, just been annoying. Both tyres have plenty of tread left. Quote Link to comment Share on other sites More sharing options...
88 Zed Posted July 28, 2016 Author Share Posted July 28, 2016 (edited) Now the alarm has gone off twice today....its got all the signs of a bad battery Same codes all appearing at once, while stationary (just started) Sent from my iPhone using Tapatalk Edited July 28, 2016 by 88 Zed Quote Link to comment Share on other sites More sharing options...
