Matti350 Posted July 22, 2016 Share Posted July 22, 2016 Hi, I'm not sure if this is the place to post this but, Recently my passenger window won't go up or down when shutting or opening the door! normally it will go down a few mm when opening the door and then go up a few mm when shutting the door? Has Anyone got any ideas as to what would have caused it to stop working ? ThanksðŸ‘🼠Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 22, 2016 Share Posted July 22, 2016 (edited) Any chance that you may have accidentally knocked the lock switch on the driver's side. ? Ignore that and try a reset. Edited July 22, 2016 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Matti350 Posted July 23, 2016 Author Share Posted July 23, 2016 Ok cheers, Do you happen to know the reset procedure ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
davey_83 Posted July 23, 2016 Share Posted July 23, 2016 Door closed Ignition on Send the window down all the way and hold down for 3 seconds Release Send window up all the way and hold for 3 seconds Done Maybe have to do a couple cycles, you're effectively telling the motor where tdc and bdc are 1 Quote Link to comment Share on other sites More sharing options...
