Dicky Posted July 22, 2016 Share Posted July 22, 2016 Apologies but Im in a dilemma about how to connect these lights. For those who have them ....do you think it's better to connect the brake light wiring to the Fog connection and the Fog connection to the Brake wiring IE reverse them. Since the Brake function LEDs are much brighter than the Fog LEDs this would give brighter Fog lights and we don't need the CarLab brake lights to be bright because we already have the oem brake lights. Hope that makes sense.....what do you think??? Quote Link to comment Share on other sites More sharing options...
Dicky Posted July 23, 2016 Author Share Posted July 23, 2016 To late! Decided to connect them as supplied and see how the mot goes. If there's any problems I'll reverse the brake and fog connections as I've said. By the way these light units make a world of difference and are much better than the oem units. If you buy a set you will probably find that on the offside unit one of the plastic locating tabs doesn't match up with the locating hole on the bumper. If so, just cut it off. Also as others have mentioned in earlier posts, be sure to add additional sealant along the top edge and anywhere you feel might be susceptible to water ingress. Quote Link to comment Share on other sites More sharing options...
