Juddering clutch
Tomh94
Hi guys
Just a quick one
I wondered if any of you have experienced your clutch juddering when setting off.
I am used to turbo cars so maybe I am not putting enough revs on, but my car sometimes judders along when I bring out my clutch, even up to about 1500 rpm. If I put on anymore than that it's usually fine.
It's been serviced recently and had a nissan health check. Only owned the car about 2 months so obviously still getting used to it.
Any light on the situation would be helpful.
Cheers
Judder can be caused by lots of reasons, contaminated friction material by oil from a leaking seal (unlikely) friction material warped from slipping/overheating, same goes for the flywheel friction surface,
Cold be a defective of badly adjusted clutch pedal, faulty slave cylinder,it could also be down to the way you are engaging the clutch, IE not giving enough rpm.
