Zedrush Posted January 31, 2008 Share Posted January 31, 2008 Gonna need to get some wheel spacer for rear and front. Can anyone advise me where to get good quality ones from and what the disadvantages are in having some Quote Link to comment Share on other sites More sharing options...
Digsy Posted January 31, 2008 Share Posted January 31, 2008 Why didn't you just buy wheels with the right offset? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Why didn't you just buy wheels with the right offset? Erm I did, They actually come out past the arches by 5mm. but doesnt help when the new arches are alot wider than usual Quote Link to comment Share on other sites More sharing options...
Digsy Posted January 31, 2008 Share Posted January 31, 2008 Why didn't you just buy wheels with the right offset? Erm I did, They actually come out past the arches by 5mm. but doesnt help when the new arches are alot wider than usual Sorry, mate, I don't understand. The wheels when fitted come out past the arches or sit inside the arches by 5mm? Spacers will only push them out further AFAIK. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Why didn't you just buy wheels with the right offset? Erm I did, They actually come out past the arches by 5mm. but doesnt help when the new arches are alot wider than usual Sorry, mate, I don't understand. The wheels when fitted come out past the arches or sit inside the arches by 5mm? Spacers will only push them out further AFAIK. Lol, I need them to sit out further, by quite a bit lol, I am getting a new bodykit and the wheels will look sunk in Quote Link to comment Share on other sites More sharing options...
Digsy Posted January 31, 2008 Share Posted January 31, 2008 Why didn't you just buy wheels with the right offset? Erm I did, They actually come out past the arches by 5mm. but doesnt help when the new arches are alot wider than usual Sorry, mate, I don't understand. The wheels when fitted come out past the arches or sit inside the arches by 5mm? Spacers will only push them out further AFAIK. Lol, I need them to sit out further, by quite a bit lol, I am getting a new bodykit and the wheels will look sunk in OK, I think I've got this! Without the body kit they sit outside the arches by 5mm but with the kit on they sit too far inside. You want hubcentric spacers and I think Eibach do some which should be decent quality. As for downsides, IIRC they can cause undue wear but I can't remember if its driveshafts or hubs. The bigger the spacer the worse it is. Don't know if that will be magnified as your offsets must already be pretty aggressive. HTH Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 31, 2008 Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now 1-800-S.P.A.C.K.T.A.R.D ?? As a suggestion, why not get the wheels with the offset that does stick out as far as you need with the body kit?! AFAIK, adding to unsprung weight and wear on wheel bearings are on the list for -ves. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now 1-800-S.P.A.C.K.T.A.R.D ?? As a suggestion, why not get the wheels with the offset that does stick out as far as you need with the body kit?! AFAIK, adding to unsprung weight and wear on wheel bearings are on the list for -ves. Because there are no wheels in existence that can do it and clear the brembo at the same time, unless I get a wheel off of big foot Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now 1-800-S.P.A.C.K.T.A.R.D ?? As a suggestion, why not get the wheels with the offset that does stick out as far as you need with the body kit?! AFAIK, adding to unsprung weight and wear on wheel bearings are on the list for -ves. Because there are no wheels in existence that can do it and clear the brembo at the same time, unless I get a wheel off of big foot Well there you go then.... You know your problem, lack of commitment..... Smaller bodykit?? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now 1-800-S.P.A.C.K.T.A.R.D ?? As a suggestion, why not get the wheels with the offset that does stick out as far as you need with the body kit?! AFAIK, adding to unsprung weight and wear on wheel bearings are on the list for -ves. Because there are no wheels in existence that can do it and clear the brembo at the same time, unless I get a wheel off of big foot Well there you go then.... You know your problem, lack of commitment..... Smaller bodykit?? Perhaps you should call this number you spackard 1-800-L.A.U.R.E.N.H.O.T.L.I.N.E. or do you have on speed dial?? Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 Like you need to ask you eeeediot, you know that Phil will be able to sort you out a set Dont know what kind of strain it will put on the car being really far out, Phil, Adam etc will be able to help with that I just didnt want to call em up yet again, they have a special line for me now 1-800-S.P.A.C.K.T.A.R.D ?? As a suggestion, why not get the wheels with the offset that does stick out as far as you need with the body kit?! AFAIK, adding to unsprung weight and wear on wheel bearings are on the list for -ves. Because there are no wheels in existence that can do it and clear the brembo at the same time, unless I get a wheel off of big foot Well there you go then.... You know your problem, lack of commitment..... Smaller bodykit?? Perhaps you should call this number you spackard 1-800-L.A.U.R.E.N.H.O.T.L.I.N.E. or do you have on speed dial?? Tried it, constantly engaged. PM me when you've finished. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 Ha ha ha ha nice comeback She called me for advice on how to trap you Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off In which case I've got plenty of MDF in the garage if you want a bodykit. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off spacers bang goes your handling Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 hmm the first modded Z with built on cupboards... hmm lol and a shelf Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off spacers bang goes your handling Yeah, but think of the image.... Quote Link to comment Share on other sites More sharing options...
Zedrush Posted January 31, 2008 Author Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off spacers bang goes your handling I know but Dorian there is nothing else I can do, its the only option Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off spacers bang goes your handling Yeah, but think of the image.... I am, and the 3-wheeled reliant robin overtaking him on the outside of the bend Quote Link to comment Share on other sites More sharing options...
H5 Posted January 31, 2008 Share Posted January 31, 2008 I love a bit of banter! She should start by dialling the right number. Looked outside your window recently.....?? What did Phil say about the spacers? Got Andrew and he said he has eibach ones, good price too but I got to find out what size ~I want. I think 55mm at the rear should do it and 35 at the front Going to be a bit tricky until you get the kit on isn't it? Anything else to worry about? Stress on the bearing which is inevitable, will redo tracking, but dont want to drive around with a car with swallowed wheels waiting for the spacers, ive got my image to think off spacers bang goes your handling I know but Dorian there is nothing else I can do, its the only option Ahem smaller bodykit Quote Link to comment Share on other sites More sharing options...
