03 350Z Twin Turbo
TT350
650whp capable bottom end, so 500 should be a very conservative number in terms of what the engine can do.
Might need to get slightly bigger injectors / fuel pump / fuel return system if you want to squeeze every single pony out of that engine, or perhaps just the bigger injectors.
Not sure what power the turbo kit can generate, Gareth should be here shortly to update.
so im right in thinking?
the engine and supporting mods after works been done, will be reliable..at around 500hp with boost turned up with map?
big list on the short block !
Reliability will depend on who completes the build and who does the tune.
Edited by ZMANALEX
The turbo kit flows 600+ bhp and it currently has 600cc injectors. They say 1cc per hp.
It was running 450bhp on LESS than stock boost. They turned it down because it was making more power than Power Enterprise claim so getting away with same figures but less boost.
  • 3 weeks later...
