Can someone explain my camber?
Djb92
Hi all, as the above says I'm rather clueless as regards wheel aliment and Ihave no idea if this is correct for an oem car. Can someone explain why my camber seems to be so far out on the left side on both the front and rear and yet on the right it is set straight down the middle?
Many thanks
Had similar other week bobbyz but the lad doin job told me if he tried to undo it could shear . Didn't charge me just said bring it back when you free em off or better still replace . Get ready if you buy em from Nissan. My wallet is still smarting.
I know that they weren't seized as I freed them both off before taking them there after a different place refused to touch them incase they sheared off the bolt. so I know they were definitely able to adjust them.
