Toe bolts help!.
GARGOYLE
Please help me
I needed new toe bolts to replace the rusty old ones so i ordered eibach camber arm kit where you need to make the hole longer for the toe bolt. So i took the zed to the garage i use gave them the box of parts and they fitted them.
The question i have is, they put the toe bolts in the camber arm bolt hole and not in the spring bucket hole is this right or wrong and if it's wrong how dangerous is it?
Any info would be appreciated.
Sent from my SM-T210 using Tapatalk
Haha what kind garage did you take your car to.
Yeah its wrong. It wont be dangerous though you will just need to swap over the bolts really.
But they made the longer holes on the camber bolt holes.
How bad is that ?
How bad is that ?
Thats not bad at all as it will still have the bolt and washer set up like the toe bolt for adjustment.
