Ollydykins Posted June 29, 2016 Share Posted June 29, 2016 (edited) Had the bottom held with a rag and mole grips, but the whole thing came out, this is no biggy right?, CANNOT for the life of me separate the gearknob (which I'm trying to change) from the rod. Please help!!!! Currently Sat here!! Olly Edited June 30, 2016 by Ollydykins Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted June 29, 2016 Share Posted June 29, 2016 Oh dear. Get some heat on the gear knob to see if u can break the lock tight. Quote Link to comment Share on other sites More sharing options...
Ollydykins Posted June 29, 2016 Author Share Posted June 29, 2016 Yeah got it off, RIP to my oem one though, and got it all on ok, replaced the gator aswell, but NOW I've got the problem of putting the silver trim on... It won't go on, and I'm about to just throw it 😤 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 29, 2016 Share Posted June 29, 2016 See stuff like this Olly is why I'm more than happy to pay garages to work on my car for me most times. I mean I've work on loads of cars (my own & other peoples when I've worked in garages) but to quote Roger Murtaugh (Danny Glover in Lethal Weapon) "I'm too old for this sh*t!". Have you got it sorted now then? Quote Link to comment Share on other sites More sharing options...
Ollydykins Posted June 30, 2016 Author Share Posted June 30, 2016 Actually yes, through pure frustration (and frequent time outs) it was just very hard locktite .... Just can't get this thing back on -.- ... Won't clip all the way round... And the garages around me were going to charge about £20-£30 and I read a thread which said it was easy.... Easy if you don't have a short temper and a rock hard gearknob... 2 Quote Link to comment Share on other sites More sharing options...
RS8055 Posted June 30, 2016 Share Posted June 30, 2016 (edited) "through pure frustration (and frequent time outs) it was just very hard locktite .... Easy if you don't have a short temper and a rock hard gearknob... I am exactly the same as you Olly... I lose my temper so easily and end up just giving myself a timeout... but it all works out in the end usually. You get so much more satisfaction from doing it yourself! haha ... even if you are almost on the verge of suffering a stroke in the process! Edited June 30, 2016 by RS8055 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 30, 2016 Share Posted June 30, 2016 Olly I haven't seen how that silver ring goes on but does it have small tabs or something then? If this makes sense ~ You might have to cut your gear gaiter in the places where the tabs meet up to give it the room it needs to locate. I'm assuming the alcantara gear gaiter is thicker than OEM which is what's causing you an issue. I do agree with RS above though that you get so much satisfaction from doing these jobs yourself. Quote Link to comment Share on other sites More sharing options...
14N Posted June 30, 2016 Share Posted June 30, 2016 I'm going from memory now (which, has let me down before), but I think you've got the gaiter fitted incorrectly. It should pass underneath the ring(s) you're trying to attach the silver ring to, not over the top. EDIT: There are tabs on the gaiter that are spaced in different locations. By the looks of the stitching on yours, you don't have these in the right place anyway FURTHER EDIT: (Memory is coming back to me). There are two plastic rings that the gaiter sits in that are held together with plastic tabs and these are screwed to the underside of the centre console. Unscrew the two rings (still fixed together) prise them apart (making note of the tabs). You should then see the different location tabs for the gaiter. Pass the gaiter the other side of the rings than you have, locating the pins where they 'should' be (I imagine the stitching will be facing forward and backwards). It's basically a reversal of everything you should of done to remove the original gaiter! Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted June 30, 2016 Share Posted June 30, 2016 All that to fit that knob Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 30, 2016 Share Posted June 30, 2016 The gaiter should have holes. The tabs on the ring will slot through the gaiter and clip into place. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
