wilo Posted June 29, 2016 Share Posted June 29, 2016 hi guys iv just hit a dip on my drive and the nismo v2 bumper is very loose now . i cant seem to find the fixing points for it ...can anyone advise please Quote Link to comment Share on other sites More sharing options...
Stan Posted June 29, 2016 Share Posted June 29, 2016 I can only advise where the stock mounting points are if that's any help? - 6 black plastic poppers on top near the slam panel, 3 screws underneath the lights (pull back the arch liner while on full lock, or just remove the wheels) and 8 or 10 bolts underneath the leading edge of the bumper. 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted June 29, 2016 Author Share Posted June 29, 2016 I can only advise where the stock mounting points are if that's any help? - 6 black plastic poppers on top near the slam panel, 3 screws underneath the lights (pull back the arch liner while on full lock, or just remove the wheels) and 8 or 10 bolts underneath the leading edge of the bumper. thank you.dont have an under tray to fix the bottom part of the bumper too. also do i need to remove the headlights ?. its far worse (wobbly) around the offside headlight so hoping iv not snapped anything Quote Link to comment Share on other sites More sharing options...
Stan Posted June 29, 2016 Share Posted June 29, 2016 I didn't remove my headlights last time I took my oem bumper off. If you can pull the arch liner towards the rear of the car you should see 2 screws pointing upwards that hold the edge of the bumper on, and a lone screw on a metal bracket that clips to near the fender. This is assuming that the mounting points are the same on an aftermarket bumper. You may find when you pull back the arch liner that the bodyshop has fixed it another way, but hopefully it'll be visible. Quote Link to comment Share on other sites More sharing options...
wilo Posted June 29, 2016 Author Share Posted June 29, 2016 I didn't remove my headlights last time I took my oem bumper off. If you can pull the arch liner towards the rear of the car you should see 2 screws pointing upwards that hold the edge of the bumper on, and a lone screw on a metal bracket that clips to near the fender. This is assuming that the mounting points are the same on an aftermarket bumper. You may find when you pull back the arch liner that the bodyshop has fixed it another way, but hopefully it'll be visible. cheers stan for the info..iv got it booked into a friends garrage tomorrow for a grinding noise coming from front wheel so ill check while its up on ramps Quote Link to comment Share on other sites More sharing options...
