LDUNKZ18 Posted June 26, 2016 Share Posted June 26, 2016 so today i realized that i don't have a coolant expansion tank next to my washer jet funnel and power steering tank... i was actually looking at my mates z and it dawned on me i dont have one... the car runs fine and temp sits at average temp, full heat through heaters also, any idea why the bottle would be deleted? should i get one again or leave it if its fine the way it is? 1 Quote Link to comment Share on other sites More sharing options...
monkeybrain1234 Posted June 26, 2016 Share Posted June 26, 2016 Picture of your engine bay may help . . . .. Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 26, 2016 Share Posted June 26, 2016 (edited) You must have one somewhere. If you don't, your cooling system would've burst by now or be massively under filled. Edited June 27, 2016 by Ekona 1 Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted June 27, 2016 Author Share Posted June 27, 2016 I'll take a pic tonight. Its a 04 de model.. maybe there is one hidden somewhere but definitely not one where its meant to be. Its been on over 3 hour journeys and its fine.. very strange Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 27, 2016 Share Posted June 27, 2016 You don't necessarily need an expansion tank, if the system is designed to run without IE it can take the pressure, and the rad cap is of a higher pressure its fine, cars never used to run an expansion tank, its just a good way of ensuring that the system is always toped up should the system overheat. Having said that the Z system IS designed to run with an expansion tank, so in order to run without yours must have a higher pressure rad cap, so I would refit the correct type of tank and the std rad cap. Quote Link to comment Share on other sites More sharing options...
veilside z Posted June 27, 2016 Share Posted June 27, 2016 How strange :wacko: Quote Link to comment Share on other sites More sharing options...
The Big Miester Posted June 27, 2016 Share Posted June 27, 2016 Not sure if Iam correct on this one so apdo correct me if Iam but there is a coolant called Waterless and higher the boiling point in fact I think it Doesn't boil or at very silly temp..!,An old Wheeler Dealers I think they put it in a TR6 and Ed took the radiator cap when the car was up to temp and running. So if yours has this in the system you may not requie expansion bottle,plus another thing it is lifetime no need to change like a normal Antifreeze that you need to change. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 27, 2016 Share Posted June 27, 2016 Not sure if Iam correct on this one so apdo correct me if Iam but there is a coolant called Waterless and higher the boiling point in fact I think it Doesn't boil or at very silly temp..!,An old Wheeler Dealers I think they put it in a TR6 and Ed took the radiator cap when the car was up to temp and running. So if yours has this in the system you may not requie expansion bottle,plus another thing it is lifetime no need to change like a normal Antifreeze that you need to change. "Evans Coolant has a high boiling point of 375F at atmospheric pressure. While it does not need pressure to raise its boiling point, we do not recommend modifying the system to hold zero pressure. It will expand 7% at operating temperature so you will notice some movement to the expansion tank, but it doesn't build pressure like water does." Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted June 27, 2016 Author Share Posted June 27, 2016 Good reason to buy a weapon r coolant tank.. will need the pas one too so it looks the part haha Quote Link to comment Share on other sites More sharing options...
