Dicky Posted June 25, 2016 Share Posted June 25, 2016 Anyone know where the IPDM box is located (intelligent power distribution module). I'm looking to check Fuse 87 which supplies the Screen washer motor. The module may be intelligent but the guy who decided to hide it certainly wasn't !! According to the USA manual it's in the battery compartment, but I've had all the covers off and no fuse for washer motor to be had. Also looked under the small cover down by the accelerator pedal and on the passanger side but no signs of fuse 87. HELP it raining and I'm desperate for a cup of tea and I'm cold and I'm wet and I'm aching and I'm fed up and....and....etc etc Quote Link to comment Share on other sites More sharing options...
Rob332 Posted June 25, 2016 Share Posted June 25, 2016 (edited) The fuse for the screen wash motor is in the battery tray, but you need to remove part of the scuttle trim to get to it. When I checked mine a few months ago it turned out to be the motor that was faulty. There should be a diagram on the underside of the cover so you can work out which fuse it is. There are a few videos on you tube if you search for 350z fuse box. Edited June 25, 2016 by Rob332 Quote Link to comment Share on other sites More sharing options...
Dicky Posted June 25, 2016 Author Share Posted June 25, 2016 The fuse for the screen wash motor is in the battery tray, but you need to remove part of the scuttle trim to get to it. When I checked mine a few months ago it turned out to be the motor that was faulty. There should be a diagram on the underside of the cover so you can work out which fuse it is. There are a few videos on you tube if you search for 350z fuse box. Yeah I took the battery cover and the surrounding covers off which revealed only an electrical box containing one relay. Do you have to take the battery out to see it ? I'll have a look on You tube.mthwnks for your help Quote Link to comment Share on other sites More sharing options...
Rob332 Posted June 25, 2016 Share Posted June 25, 2016 Hopefully this link works, but this shows how to get to the fusebox 1 Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted June 25, 2016 Share Posted June 25, 2016 Yeah it works rob. Sent from my iPad using a hammer and chisel... Quote Link to comment Share on other sites More sharing options...
Dicky Posted June 25, 2016 Author Share Posted June 25, 2016 Found it Rob thanks. Hadn't taken enough plastic bits off to be able to see it. The fuse is good so onto the motor. Thanks again Quote Link to comment Share on other sites More sharing options...
Rob332 Posted June 25, 2016 Share Posted June 25, 2016 You can get the motor\pump from e bay. That's where I got mine. They are about £8. 1 Quote Link to comment Share on other sites More sharing options...
