lukewilde Posted June 21, 2016 Share Posted June 21, 2016 (edited) Fitted my new cobra exhaust the other day and initially had the issue with a bracket at the back which one of the back box brackets was knocking on, but the mid pipe is only about 5-10mm off of the m brace if that's what it's called Any ideas on how to sort it? Can't see that it could sit any higher, but haven't found anyone else with the same issue Edited June 21, 2016 by lukewilde Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted June 23, 2016 Share Posted June 23, 2016 Anything else aftermarket?there are manufacture tolerances in some aftermarket cats and Y pipes that can cause the exhaust to be slightly out, you could try and loosen all the components and wedge a piece of wood above the section where its touching and then start re-tightening all the parts starting from the front to the back. 1 Quote Link to comment Share on other sites More sharing options...
Lexx Posted June 24, 2016 Share Posted June 24, 2016 Remove W brace and then fit some spacer washers between it and the chassis when you refit it. Quote Link to comment Share on other sites More sharing options...
