bod_bod Posted June 20, 2016 Share Posted June 20, 2016 Hi all, I'm looking to upgrade the front and rear brakes on my 53 plate, base spec import 350z. Its currently running the non brembo brake setup and the callipers are all starting to seize. Ideally looking to have 6 pot callipers on the front and 4 on the rears. Ive been looking at few kits k sport, pb etc. Just looking for some advice on what other people are running and what everyone would recomend before i go spending my money. Im looking at spending around £2,000. Thanks. Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 20, 2016 Share Posted June 20, 2016 Probably not what you want to hear but unless you track the car heavily, a bbk is wasted, a std brembo caliper with decent discs and pads will give you more than enough stopping power for fast road or general track days. 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted June 20, 2016 Share Posted June 20, 2016 (edited) As above, for normal / spirited road use, BBK it's going to be a bit of overkill. Better Stoptech discs and Hawk pads for instance will do perfectly. Alternatively, find an used set of 350z GT Brembo brakes and replace the pads, discs and lines. Have a browse here for some inspiration. http://www.torqen.uk/17-brakes For BBK, have a look at our own kit here: http://www.torqen.uk/nissan/350z/brakes/big-brake-kits/1654-350z-torqen-big-brake-kit-trq-bbk350.html PM me for a price for 6 / 4 pot setup. Edited June 20, 2016 by Adrian@TORQEN Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted June 20, 2016 Share Posted June 20, 2016 I totally agree that a standard Brembo calliper set up is perfectly adequate (as Adrian said Stoptech and Hawke is a great combo) BUT slipping on a Torqen monster kit brings an added dimension to the phrase "stop on a sixpence!" Progressive, great feedback and utterly fade free - plus they look great! David. Quote Link to comment Share on other sites More sharing options...
bod_bod Posted June 20, 2016 Author Share Posted June 20, 2016 I won't be going on a track anytime soon, i didn't fancy buying a second hand set due to not wanting any calliper issues in the near future. But if it will save me a hell of a lot of money which could be spend else where then i will take your advice and hunt for some brembo's. I will send you a pm Adrian to hook me up with the correct pads and disks. Many thanks guys! Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 20, 2016 Share Posted June 20, 2016 I too echo what all of the above have said. I ran my supercharged (436Bhp) 350Z on the standard Brembos and I had no issues stopping ~ the set up was: Motul RBF600 brake fluid Goodridge Stainless steel brake lines EBC Turbo Groove brake discs Ferodo DS2500 brake pads It also went on track so for fast road you'll be fine with a similar set up imo. Give zmanalex or Emperor Tuning a PM (private message) to see if either of them has good used Brembos in stock. zmanalex: http://www.350z-uk.com/user/9648-zmanalex/ Emperor Tuning: http://www.350z-uk.com/forum/232-emperor-tuning/ Good luck. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 20, 2016 Share Posted June 20, 2016 Over all power for stopping is mainly down to pad friction and tire grip. I can lock the tires even with R888 on track so more brakes would only help with fade issues not over all stopping distance etc. 2 Quote Link to comment Share on other sites More sharing options...
bod_bod Posted June 21, 2016 Author Share Posted June 21, 2016 Thanks all for the advice, i will send a few pm's out and decide over the next few weeks which route i will take. Quote Link to comment Share on other sites More sharing options...
