Individual ITB's for HR Engines
Drayvn
Lovely. ITBs sound utterly epic. Although looking on the Jenvey site the DE kit does not fit under a 350z bonnet so would need some clever modifications there if this is the case for the HR.
If you read further down right at the bottom above where he starts on about emailing him. Further development will be done on Curved Air Horns to fit under the Factory Hood!!!
They're a bit good looking. Dumb question, but how the feck is the air filtered?
You'd need a custom airbox, unless they can offer a solution. Sasha Anis (of OnPoint) had / has one on his HR with ITBs.
I wonder if a DE set would fit under the car that had an HR bonnet. Also the custom ECU would be a bit of a pain to get right.
With some work and a Link G4+plug n Play ECU and a BMW M3 E46 throttle motor it will be a reasonable easy job to sort out
We have our HR running on Syvecs S8 so that will run on ITB's easily. We will also be developing a Link G4+ Thunder/Fury ecu upgrade soon as well.
Thanks
Edited by Mark@Abbey m/s
