Barkerm87 Posted June 15, 2016 Share Posted June 15, 2016 Got a water leak. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 15, 2016 Share Posted June 15, 2016 (edited) Where is the leak mate? If it's top corner (90deg window edge), you might be able to sort it by stuffing some sponge or material under the seal. Mine has collapsed and water usually goes in from there. If you need one, try Jon@EmperorTuning , he's breaking a zed now and should have one ready to deliver. Alternative, try Edited June 15, 2016 by veeg33 1 Quote Link to comment Share on other sites More sharing options...
Barkerm87 Posted June 15, 2016 Author Share Posted June 15, 2016 Thanks! Yeah exactly where you said! It annoying leaks into the satellite speaker 😔 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 15, 2016 Share Posted June 15, 2016 Here's a little guide --> http://www.350z-uk.com/topic/106283-how-to-improve-door-seal-effectiveness/ 1 Quote Link to comment Share on other sites More sharing options...
Jon T Posted June 15, 2016 Share Posted June 15, 2016 Incase they are required: http://www.ebay.co.uk/itm/Nissan-350Z-Door-Aperture-Inner-Rubber-Surround-Seal-Lining-O-S-Right-Driver-/281579924024?fits=Model%3A350+Z&hash=item418f78aa38:g:VvUAAOSwUuFW02~Q http://www.ebay.co.uk/itm/Nissan-350Z-Upper-Door-Window-Rubber-Weather-Seal-Trim-O-S-Right-Driver-/282016829579?fits=Model%3A350+Z&hash=item41a983508b:g:I~gAAOSwyQtV1yGw 2 Quote Link to comment Share on other sites More sharing options...
Blue Straggler Posted November 18, 2016 Share Posted November 18, 2016 Hi Jon. It so happens that I am after a passenger side weather strip but I see that the one you have for sale is the same as mine I.e the handle-end tab with the screw has snapped off. Your eBay description says that the strip can be fitted without this tab. I've been trying with mine, thinking that some sort of clip/rail would hook to a counterpart on the door, but I've had no success. What's the trick? I don't doubt that i am just missing a bit of "knack"! I did try to glue the screw tab back to main weather strip. This worked....for three days! Quote Link to comment Share on other sites More sharing options...
Jon T Posted November 18, 2016 Share Posted November 18, 2016 Hi Jon. It so happens that I am after a passenger side weather strip but I see that the one you have for sale is the same as mine I.e the handle-end tab with the screw has snapped off. Your eBay description says that the strip can be fitted without this tab. I've been trying with mine, thinking that some sort of clip/rail would hook to a counterpart on the door, but I've had no success. What's the trick? I don't doubt that i am just missing a bit of "knack"! I did try to glue the screw tab back to main weather strip. This worked....for three days! Hey blue this one has the tab: http://www.ebay.co.uk/itm/Nissan-350Z-Door-Window-Upper-Weather-Strip-Cap-Lining-N-S-Left-Passenger-/282259353478?ssPageName=STRK:MESE:IT Quote Link to comment Share on other sites More sharing options...
Blue Straggler Posted January 13, 2017 Share Posted January 13, 2017 Jon sorry for lack of reply / lack of acknowledgement. Weird computer things going on, with my work PC putting an automatic bar on "chat forums"! Thanks again, I'll take a look Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 13, 2017 Share Posted January 13, 2017 Plenty in stock with tab if Jon does not have stock. Just drop me a PM if I can help further. Quote Link to comment Share on other sites More sharing options...
Jon T Posted January 13, 2017 Share Posted January 13, 2017 Cheers, if it's Driver side, I believe these auctions are still up: Surround seal: http://www.ebay.co.u...vUAAOSwUuFW02~Q Upper seal: http://www.ebay.co.u...~gAAOSwyQtV1yGw Quote Link to comment Share on other sites More sharing options...
