wilo Posted June 13, 2016 Share Posted June 13, 2016 only had the had car a week and over the last couple of day's I've noticed that when i turn the car off (80%) of the time I hear a rattle coming from the engine bay . any ideas guys ? only can hear this rattle on turning off engine and no other time Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted June 13, 2016 Share Posted June 13, 2016 Is this the noisy clutch chatter that is prevalent on the 350s? If you depress the clutch when you switch off the engine is it noticeably quieter? Quote Link to comment Share on other sites More sharing options...
wilo Posted June 13, 2016 Author Share Posted June 13, 2016 Is this the noisy clutch chatter that is prevalent on the 350s? If you depress the clutch when you switch off the engine is it noticeably quieter? depressing clutch makes no difference and its intermittent .i do have slight thrust bearing noise but this other noise is a deeper louder rattle Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted June 13, 2016 Share Posted June 13, 2016 In that case I don't know mate. Somebody else with much more mechanical knowledge than me will be along to suggest something I am sure. I know my clutch chatters reasonably loudly and so switching off the engine I can hear that but it is much better if I turn engine off with clutch depressed but if yours isnt the same I couldn't really comment. Could it be an engine mount or bush or something? 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 13, 2016 Share Posted June 13, 2016 Flywheel, cat heat shield, strut brace interfering with bonnet are 3 that spring to mind. 1 Quote Link to comment Share on other sites More sharing options...
stubzie83 Posted June 15, 2016 Share Posted June 15, 2016 Found it to be the flywheel on mine when it was worn. Didn't make the rattle after it was replaced for at least 20k miles. Was then starting to come back a little but wasn't as bad as before the replacement Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted June 20, 2016 Share Posted June 20, 2016 If somebody has fiddled with the strut in the bay and hasn't been tightened enough, that can rattle. Bit of a long shot but you never know. Quote Link to comment Share on other sites More sharing options...
modo Posted June 20, 2016 Share Posted June 20, 2016 Fan housing? Quote Link to comment Share on other sites More sharing options...
