Exterior window seal/trim
Treybleed
How do you get them off Alex? I have no problems with them.
I've got a really nice passenger one. £25 posted.
I also have some not so nice driver ones, but please PM if interested etc.
Thanks
Jon
I always find that the clips are rusted and seized on to the door shell and unless you are working from inside the door with the drop glass removed I have found that they damage to easily on removal.
You will have to send me a "how to" Jon: :lol:
FYI - I'll tell you how I do it:
So I remove wing mirror and put window down. Un-do the little screw at the end. Then I jimmy the rear end of the trim up ever-so-slightly. The I made a tool that is profiled to the trim and door top. The I use the tool to push the trim from the front end backwards, and she slides right off. hope if helps.
Thanks for the info, i'll be visiting Nissan in a couple days time as they are cutting me a spare key, I will inquire how much they charge for new ones first.. if I need to take out a second mortgage for it i'll be touch Jon@Emperor ! thanks
Magic
  • 2 months later...
Thanks
Jon
Hi, do you still have this?
Not to worry, Ive managed to repair mine
Edited by gareth29
