Rob.2712 Posted June 9, 2016 Share Posted June 9, 2016 Looking into some 30mm springs for my zed, seen alot to do with rear camber arms? Would this be essential on only a 30mm drop? Sent from my MotoE2(4G-LTE) using Tapatalk Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 10, 2016 Share Posted June 10, 2016 Essential? No. Recommended? Yes. When you drop it 30mm the rear camber will most likely not be able to be adjusted within factory specs using the standard adjustable bolts, so camber arms will be required. However, if you're happy to run 3° camber, then don't worry about it Quote Link to comment Share on other sites More sharing options...
Rob.2712 Posted June 12, 2016 Author Share Posted June 12, 2016 Thanks for your reply, camber arms ordered 👠Sent from my MotoE2(4G-LTE) using Tapatalk Quote Link to comment Share on other sites More sharing options...
