350z grunting noise 5 secs or so after pulling of only after startup.
350David
Posted this in 370Z forum by accident!
Has anyone else experienced a strange 'grunting' noise (almost like an angry gasp) after starting up, about 5 secs or so after pulling off? Doesn't happen after a stop, just startup and only lasts a second. Seems louder when engine has been off for a while and cooled down. Worried it's something nasty but it's just started over last couple of days. Has anyone had this problem or knows what it could be?
Thanks all.
Thanks Chris, funnily enough I thought that this morning when I took the car out. I'll try that revving idea and see if it does it on standstill. It might be a timing coincidence but it seems to happen just after changing into 2nd gear. But my driver side window motor is getting fixed this week so I have been using the AC more recently so, who knows?
Thanks all.
Does it sound like when your ABS comes on? Like a spring unwinding/grinding? If so, this is competently normal. Your ABS will occasionally self test on startup.
I reckon this is the ABS self check - happens at about 5-7mph after pulling away after a fresh engine start. Completely normal.
(FYI if you get up to that speed then immediately put your foot on the brake you can feel the self-check vibration up through the brake pedal - like if the ABS was actually applied)
