Mapping cost to switch off O2 sensors?
thedon
I regularly get P1146/7 error codes because I have HFCs.
The car has already been Uprev mapped - how much just to switch off the O2 sensors?
Also anyone know somewhere that can do this near Suffolk? Thanks.
Thanks Alex, but Horsham obviously didn't. It was mapped before my time, hence wondering how much it would likely cost to simply switch them off now.
Would you suggest spacers as a cheaper option?
Strange , we usually do
Spacers might be a cheaper option than fuel to go somewhere to get them switched off
If the o2 sensor doesn't report back with a fault after a ecu tweak, how will you know when they are faulty, or is it just the tolerance level that is altered?
Its the post cat sensors that are switched off, the pre cat ones are still used .
