C-Fed Posted June 1, 2016 Share Posted June 1, 2016 Since getting the cobra exhaust fitted I could hear a sort of knocking noise coming from it somewhere... My first thoughts were the brace underneath but there's a good two inches of clearance thanks to th cobras design. However I did notice this bit at the rear hanger. You can see the hanger is resting on it but as far as I can see that Whole bit unbolts. Just wondered what it was before I remove it? Doesn't seem like that bit does anything? Quote Link to comment Share on other sites More sharing options...
C-Fed Posted June 1, 2016 Author Share Posted June 1, 2016 For anyone whith same issue just unbolt the lot. Job done Quote Link to comment Share on other sites More sharing options...
Brandon350Z Posted June 4, 2016 Share Posted June 4, 2016 I had this issue with my Cobra exhaust I cut a hole where the hangar was. Sent from my D6603 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
ZonixX Posted June 5, 2016 Share Posted June 5, 2016 Unbolt the cover, cut a small hole in it, refit Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 5, 2016 Share Posted June 5, 2016 Looks like the hanger isn't fully in either. Should it not be elbow deep in the mount? 1 Quote Link to comment Share on other sites More sharing options...
colesl4w Posted June 6, 2016 Share Posted June 6, 2016 Can't really see where that is on the car, but is it at the diff? I had to have the diff shield removed to fit an Ark Grip. Quote Link to comment Share on other sites More sharing options...
ZonixX Posted June 7, 2016 Share Posted June 7, 2016 this is behind the rear drivers wheel, the rusty metal is holding a plastic deflector, part of the underbody aero... by the way, whilst cutting the metal piece - an excellent opportunity to get rid of the rust Quote Link to comment Share on other sites More sharing options...
