88 Zed Posted May 26, 2016 Share Posted May 26, 2016 So ive just got home after loosing my clutch pedal on the motorway. After a frustrating drive with no clutch ive had a look at the damage. The slave cylinder (replaced at christmas with a clutch and flywheel) Has extended to much and popped out because the clutch fork appears to have moved. I think the pivot ball has come off and the fork has moved, cant see for sure lying down on the floor with the torch on my phone covered in brake fluid! Has anyone experienced this before and if so is there a uprated part i cant get hold of? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 26, 2016 Share Posted May 26, 2016 (edited) A common issue if you upgrade the clutch. You have the choice of OEM or upgraded pivot balls . The Chromoly pivot ball is much stronger than the OEM carbon steel. Best to replace the washer and the retaining spring as well. Edited May 26, 2016 by ZMANALEX 1 Quote Link to comment Share on other sites More sharing options...
88 Zed Posted May 26, 2016 Author Share Posted May 26, 2016 Great thanks! Any idea where i can get the upgraded part? I don't fancy driving home in rush hour with no clutch again Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 26, 2016 Share Posted May 26, 2016 (edited) http://clarkmotorspo...----41mm/113280 There is also a 52mm. Here it is: http://clarkmotorsport.co.uk/parts/Uprated-Clutch-Pivot-Ball---52mm/113279 Edited May 26, 2016 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
88 Zed Posted May 27, 2016 Author Share Posted May 27, 2016 Brilliant, thanks alex Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
88 Zed Posted June 4, 2016 Author Share Posted June 4, 2016 All sorted, no wonder it failed, the old pivot ball wasnt threaded all the way in and it had some suspicious looking tack welds on it...... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
88 Zed Posted June 4, 2016 Author Share Posted June 4, 2016 Drilled the rest of it out and cleaned the threads with a tap, the new one fits snug now. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jixaman Posted June 9, 2016 Share Posted June 9, 2016 Feck, ah remember doin that job a few years back, havin the scisor lift helped... That and 6 or 7 ratchet extensions to get at the top 2 bolts... 1 Quote Link to comment Share on other sites More sharing options...
88 Zed Posted June 12, 2016 Author Share Posted June 12, 2016 Its not a bad job to do at all really, just frustrating doing it again so soon as j changed the clutch and flywheel at christmas! My own fault for not noticing it then probably. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Cerofigg Posted February 15, 2020 Share Posted February 15, 2020 Would pivot ball failure explain air in the line? I've replaced slave, can't find a leak anywhere and have bled the system a hundred times (still getting air) in completely at a loss. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 15, 2020 Share Posted February 15, 2020 No, You don't say if your car is a DE or an HR. Pivot ball failure will not generate an air lock. If you are following the correct bleed system then the air in the hydraulic system should dissipate. Not following the correct bleed procedure is the usual culprit, however the correct pedal adjustment is also important. Perhaps you have fitted the wrong slave cyl. or you may have a faulty master cyl. However, my money is on the bleed procedure, which can sometimes be a bit tricky and be a real ball ache. Quote Link to comment Share on other sites More sharing options...
Cerofigg Posted February 15, 2020 Share Posted February 15, 2020 Thanks so much, that's what I suspected Quote Link to comment Share on other sites More sharing options...
Cerofigg Posted February 15, 2020 Share Posted February 15, 2020 6 hours ago, ZMANALEX said: No, You don't say if your car is a DE or an HR. Pivot ball failure will not generate an air lock. If you are following the correct bleed system then the air in the hydraulic system should dissipate. Not following the correct bleed procedure is the usual culprit, however the correct pedal adjustment is also important. Perhaps you have fitted the wrong slave cyl. or you may have a faulty master cyl. However, my money is on the bleed procedure, which can sometimes be a bit tricky and be a real ball ache. Do you have a suggestion on best way to bleed? It's DE by the way 6 hours ago, ZMANALEX said: No, You don't say if your car is a DE or an HR. Pivot ball failure will not generate an air lock. If you are following the correct bleed system then the air in the hydraulic system should dissipate. Not following the correct bleed procedure is the usual culprit, however the correct pedal adjustment is also important. Perhaps you have fitted the wrong slave cyl. or you may have a faulty master cyl. However, my money is on the bleed procedure, which can sometimes be a bit tricky and be a real ball ache. Regards Quote Link to comment Share on other sites More sharing options...
