Any advice on how to clean front headlights?
Stan350Z
Noticed a rough film of grease that must have built up over the years (we have a 2005 DE Roadster) and not entirely sure what best products to use to clean it off without scratching the lenses. Gives the lenses an unattractive cloudy look.
Anyone else got this, or even better a solution?
Cheers in advance :thumbs:
I just polished mine last week using Maguires headlights kit (https://www.amazon.co.uk/MEGUIARS-G1900K-Headlight-Restoration-Kit/dp/B001O7I7FS) cost about £25 ish. Follow the steps to sand your headlights slowly until it is white ish. Yes, this might sound scary but it works. Completely transformed it and it looks almost new. Make sure you use some detailing masking tape around your headlights to avoid sanding your paintwork. Just make sure you seal it with some UV wax (Turtle Wax ICE - http://www.carmaniaonline.co.uk/turtle wax ice synthetic paste polish kit- turtle wax- ice-car polish) I build up around 5 layers of wax so that the newly polished headlights are protected against UV which is the root cause of it turning yellowish
Edit: DA = Dual Action (bed time story here explaining http://www.detailingworld.co.uk/forum/showthread.php?t=63859 )
Edited by veeg33
P.S. what does d/a stand for in this context?!
Dual Action. A machine polisher that oscillates rather than just rotates (which would be known as rotary). Not the cheapest way to polish your headlights if you don't already have one though...
It's not grease it's the surface of the plastic breaking down from the sun. Buy a headlight restore kit and it will sort it out. :)
I just polished mine last week using Maguires headlights kit (https://www.amazon.c...t/dp/B001O7I7FS) cost about £25 ish. Follow the steps to sand your headlights slowly until it is white ish. Yes, this might sound scary but it works. Completely transformed it and it looks almost new. Make sure you use some detailing masking tape around your headlights to avoid sanding your paintwork. Just make sure you seal it with some UV wax (Turtle Wax ICE - http://www.carmaniaonline.co.uk/turtle wax ice synthetic paste polish kit- turtle wax- ice-car polish) I build up around 5 layers of wax so that the newly polished headlights are protected against UV which is the root cause of it turning yellowish
Edit: DA = Dual Action (bed time story here explaining http://www.detailing...ead.php?t=63859 )
^^ What these guys said. ;)
Used the Megs headlight restore kit on my Zed and it brought the headlights up like new. :thumbs:
Meguires headlight kit ordered - thanks for all the advice :thumbs:
Turtle ICE wax paste kit... £57 on Amazon?! What's the stuff made of?!
Looks like the product has been discontinued hence seller bumping price up to make a profit!! I got mine for less than a tenner shipped.
Try this maybe (build up a few coats)--> https://www.amazon.co.uk/Surface-Sealant-Coating-Repellent-Plastic/dp/B00A3S1RGU/ref=pd_bxgy_263_img_2?ie=UTF8&refRID=B7SEPM0366PGVWDYN1NZ. Make sure to keep it away from paint (just in case)
