CountKyle Posted May 23, 2016 Share Posted May 23, 2016 My aux belts have started squealing, and having inspected them they're due a change. I've managed to loosen off the right-hand side locking nut (14mm) on the idler wheel no problem, but the other one is rounded and I don't have the space to try and get a smaller socket on. Is this a nut that can be replaced easily if I ruin it by loosening it with vice grips for example? Any advice nut would be appreciated! Cheers Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 23, 2016 Share Posted May 23, 2016 Yup can be replaced easily, ZmanAlex used to offer replacement nuts (17mm IIRC) with the belt kits - Clarke may do the same now Gotta get it off but a replacement should not be an issue Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted May 23, 2016 Share Posted May 23, 2016 Fairly certain one of the nuts is left hand thread but can't remember if its the locking nut or the tensioner screw. The locking nuts shouldn't be torqued that hard. Are you sure its turning the right way? Quote Link to comment Share on other sites More sharing options...
CountKyle Posted May 23, 2016 Author Share Posted May 23, 2016 I can't even get the socket on it to turn it! Quote Link to comment Share on other sites More sharing options...
kano Posted May 26, 2016 Share Posted May 26, 2016 I can't even get the socket on it to turn it! When I did mine I had to buy some of those ratchet spanners, made the job a lot easier as there's not a lot of room down there.. Quote Link to comment Share on other sites More sharing options...
Juggalo Posted May 26, 2016 Share Posted May 26, 2016 I can't even get the socket on it to turn it! That's why the last guy rounded it off. That left side one, as you look at the engine, is a pig. I couldn't even get the torque wrench in, had to guess using the right side one as a guide. Quote Link to comment Share on other sites More sharing options...
CountKyle Posted June 4, 2016 Author Share Posted June 4, 2016 I managed to replace the belts - it's a really easy job once the undertray is out the way. I had to remove one of the radiator fans so I could get a bit more room to bash the socket on - it went on eventually! I replaced both locking nuts whilst I was at as they were in a bit of a state. Quote Link to comment Share on other sites More sharing options...
