Drop links diy.
andybp
some of you may think I'm pretty tight but I just like value for money I do a really S**T job for mine so don't part with it easily so I changed my rear drop links recently for standard type non adjustable ones with pressed steel ball joints
but having dropped the car a little I didn't like the anti roll bar position so started looking for adjustable versions and was not too impressed with the quality of some and the price of others so ........
Ingredients
1 length of 18mm hexagon ally bar
2 x 10mm right hand thread rose joints + locknuts
2 x 10mm left hand thread rose joints + locknuts
8 x M10 flanged NYLOC nuts
4 x M10 button head socket screws
1 x lathe
1 x M10 right hand tap
1 x M10 left hand tap
1 x 8.5mm drill bit
cut hexagon rod to approx. length
finish to exact length in lathe (and put a chamfer on the end because it looks nice)
and while it's nicely centered in the lathe bore 8.5mm hole through the middle
I also tapped the holes in the lathe to ensure they went in straight left hand one end right hand the other
then assemble as in the picture below
Cost £25 :teeth:
these are actually the front I will make the rear tomorrow
and before someone asks why I used rose joints instead of ball joints with nice rubber seals which will last longer well the answer to that is because I felt like it and I only do 600 miles a year
Edited by andybp
Ingredients
1 x lathe
1 x 8.5mm drill bit
Cost £25 :teeth:
Fancy making a front and rear set for me 😊
