C-Fed Posted May 18, 2016 Share Posted May 18, 2016 (edited) Sorry for posting these again. Tried on a couple other threads but haven't got an answer. I bought the car with a dull clunking sound that could be heard at low speeds on uneven roads. My first thought was it was down to worn front drop links so replaced them. This cured the clunking to some extent but it's been replaced with a definite knocking/creaking. It sounds all kinds of awful. It sounds like it's front near side/central. Are roll bar bushes prone to going as well? Previous owner told me it was solid underneath and sailed through its mot. Is this noise more than likely the bushes in the compression/banana arm? Sound more creaky here Really hope I Havnt bought a lemon Many thanks. Edited May 18, 2016 by C-Fed Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 18, 2016 Author Share Posted May 18, 2016 Forgot to say car is an 55 plate on 56k miles Quote Link to comment Share on other sites More sharing options...
ZEUS Posted May 18, 2016 Share Posted May 18, 2016 Usually if it's knocking over bumps at the front and you've done the drop links then it's the banana arms. Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 18, 2016 Author Share Posted May 18, 2016 Heard there's some heat shield / under tray thing that can be loose and also cause a noise? Wonder if it's both! It does sound horrendous as you can hear. I've sourced an aftermarket arm new so will stick that on and see if it it sorts it. Just wanted to find out if where was any other culprits! Then it's on to the grinding noise when turning tight/hard right and the pulsing I've noticed coming from the clutch?! Although heard that can be a zed trait :? Quote Link to comment Share on other sites More sharing options...
ZEUS Posted May 18, 2016 Share Posted May 18, 2016 When my heat shields were loose it was a tinny rattle sound but check them anyway just to rule them out. Maybe change the power steering fluid and clutch fluid, might help? Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 18, 2016 Author Share Posted May 18, 2016 If this duel mass flywheel/clutch was on the way out could this all be signs of this dull intermittent light knocking/pulsing from the clutch when it's pressed in? The bite point is really high and it shudders a little bit unless you feather the accelerator a bit. Starting to wonder why I bought it!! Hahaha Quote Link to comment Share on other sites More sharing options...
ZEUS Posted May 18, 2016 Share Posted May 18, 2016 Bite point on Zeds is quite high as standard, they're not the best clutch to be honest. I've had mine 6 years and I'm still not used to it Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 19, 2016 Author Share Posted May 19, 2016 Oh god! I tired that clutch adjustment guide but went too far and the pedal wasn't returning all the way up so had to turn it back again. Might give it another bash and not go as far... see if it makes a difference. Are draining the clutch and steering fluid easy to do on a zed? It's not somthing I've tried before Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 19, 2016 Author Share Posted May 19, 2016 (edited) Since I've been doing so much research on the old compression arms etc, just went and had a look under the car and I don't think my bushes are standard?! They're black im sure but are they pollybushes?! Edited May 19, 2016 by C-Fed Quote Link to comment Share on other sites More sharing options...
Bigjimg Posted May 19, 2016 Share Posted May 19, 2016 Those are not standard bushes, poly bushes of some sort definately Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 19, 2016 Author Share Posted May 19, 2016 That's what I thought?! Looks nothing like the bush on the replacement arm I got. Makes me wonder what the hell the noise is then? They don't look worn out really Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 20, 2016 Author Share Posted May 20, 2016 (edited) If it's still clunking/knocking though then surly that must mean that the ball joint on the arm is the problem ? What about top mounts etc or are her normally ok? If that (assuming it is one) polly bush is alright could it be easily pressed out and swapped to the new compression arm? Edited May 20, 2016 by C-Fed Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 23, 2016 Author Share Posted May 23, 2016 Changed the front near banana arm and it's still creaking loud and has a metallic rattling over bumps. Letting the garage have a poke about see what they think. Strange. Getting my lolly bushes out into the new arm at least... Quote Link to comment Share on other sites More sharing options...
C-Fed Posted May 31, 2016 Author Share Posted May 31, 2016 Sorted. Drop link wasn't on properly! After all that it's finally fixed. What a nightmare 1 Quote Link to comment Share on other sites More sharing options...
