HOW TO: Install silver indicators in tail lights
Chris`I
This how to explains how to get to the rear indicators so that you can change them for much nicer looking silver alternatives :thumbs:
Required tools
- Small flat head screw driver
- 10mm socket
- Tissue(s)
- 2x T20 silver bulbs (Here from JDM Performance)
Repeat the same for both sides.
1. Remove the 3 dust caps on the headlight with the small flat head screwdriver and remove the 3 bolts that they uncover with a 10mm socket.
2. Starting at the rear of the light, pull it away from the body. The first of the two clips holding the light in place will pop. Next work your way towards the front of the car and pull the headlght out and back to pop the second clip. Clip locations highlighted below. Place the headlight in the boot, no need to unclip the cable.
3. Remove the current indicator bulb by twisting the housing of the bulb. Pop out the current bulb and put in the new one. Do not touch the new bulb with bare hands, use a tissue to ensure no greasy finger prints are left on the silver finish.
4. Refit the bulb holder and test the light.
5. Refit the tail light by first placing the front of the 2 clips in place and then swing the unit towards the back of the car and pop the second of the clips in. Replace the bolds and dust caps and you're done :thumbs:
Before:
After:
just thinking wether to get clear lense for fog light then get red bulb! only problem fitting it!!
do u have to remove bumper, anyone know? sure u do!!! :headhurt:
I had the same thought and I think you would have to remove the bumper. Wouldnt have thought it was a massive job, just effort getting the light unit and a bulb in the right fitting that is silver and lights up red :thumbs:
u can get a red shining light thats silver like the indicator bulbs!!! think silvertec do them!!! not sure about the lenses where to get them from but seen them about before!!!
anyone got a guide on how to remove the front and rear bumper???? :thumbs:
